I want to get access to Service Area of the hard disk, I have
- Seatgate (ST 3120026AS), (ST380815AS) , (ST3500418AS),
WD 2500KS-00MJB0 and Samsung HD103SI
ANy tips/ pointers will be highly appreciated
AJ2008 wrote:You will have great difficulty in identifying the vendor codes you would need, you would also have some problems implementing them in an environment you can work within. You would need at least mediocre skills in reverse engineering / programming to help in what you want.
Personally, if its is just for interest, you should look at accessing SA via a Terminal via the serial port of a drive such as Seagate. You can access with TTL cable and Hyper-terminal and there are lots of documented processes and commands easily searchable at this and a variety of other HDD related forums.
