Seagate ST3100528AS 7200.12 Stops cloning after 507 GB
jmcurtis81
Postby jmcurtis81 » 29.04.15, 15:10
Hey there,
Just seeing if anyone else has come across a similar problem that I am getting with a drive I am working on.
It is a 1 TB Seagate 7200.12 Drive.
I can image the first 507 Gigs approx, rest of the drive will not image though.
Does not read at full speed, but still images fairly quickly considering.
I have checked the partial clone and I can see some working data.
any Suggestions please :D
Re: Seagate ST3100528AS 7200.12 Stops cloning after 507 GB
Postby AJ2008 » 13.05.15, 11:59
I am assuming this case arrived with some FW bug you solved by regeneration translator?
If so, then its likely that you cleared a list of defects in the non-resident list that are important to the translator being built correctly.
einstein9
Postby einstein9 » 14.05.15, 15:38
there is a Tricky way of cloning the rest and continue and can be fixed
Postby AJ2008 » 14.05.15, 16:20
what is the last readable sector or first unreadable sector?
Users browsing this forum: No registered users and 23 guests
