I have HDD model ST9500325AS.
The HDD is identified perfectly. But when creating image it is extremely slow. In terminal it shows the following message continuously.
ProcessRWError -Read- at LBA 0D2466D2 Sense Code=43110081
Starting LBA of RW Request=0D2466D3 Length=FFFFFFFF
ProcessRWError -Read- at LBA 0D2466D3 Sense Code=43110081
Starting LBA of RW Request=0D2466D4 Length=FFFFFFFF
ProcessRWError -Read- at LBA 0D2466D4 Sense Code=43110081
Starting LBA of RW Request=0D2466D5 Length=FFFFFFFF
ProcessRWError -Read- at LBA 0D2466D5 Sense Code=43110081
Starting LBA of RW Request=0D2466D6 Length=FFFFFFFF
ProcessRWError -Read- at LBA 0D2466D9 Sense Code=43110081
Starting LBA of RW Request=0D2466DA Length=FFFFFFFF
Can someone provide a solution. Thanks
ST9500325AS imaging slow. Continuos message in terminal
Re: ST9500325AS imaging slow. Continuos message in terminal
Try to disable pending and relocation parameters under 'HDD ID EDIT' option
Hi, Thanks for the reply. I have done that. The HDD has 2 heads. Imaging from head 1 is perfect and fast. This message comes only with head 0. /7X shows both heads OK. But imaging of head 0 is extremely slow with lot of UNC errors with the message mentioned continuously. Any solution please
