Seagate 2TB LED:00000047 FAddr:FFFFFFFE issue
odedshankar
Postby odedshankar » 04.02.15, 07:26
Hi Folks,
I have a Seagate 2000GB Grenada which had a faulty heads looks like pre-amp was bad but i can’t see any platter damage.
I swapped the heads from a donor drive, and the drive is trying to start up, sounds are healthy indicating no platter damage, but it looks like there is some FW problem and the terminal is locked, i don’t have access to it. does anyone knows what are the short points for this PCB(see images on the link below).
Any assistance on the matter will be appreciated.
Images of the drive:
https://dl.dropboxusercontent.com/u/49559271/hdd.rar
Log from PC3K Terminal with the new heads:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0018[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0018
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0004E819
[RSRS] 0385
RECOV Servo Op=0255 Resp=0005
ProcessRWError -Read- at LBA 000000000002D894 Sense Code=40000087
RECOV Servo Op=0065 Resp=0005!
ProcessRWError -Read- at LBA 000000000002D895 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000002D895!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-0018
entec
Re: Seagate 2TB LED:00000047 FAddr:FFFFFFFE issue
Postby entec » 05.02.15, 01:16
try red pins first, and if they not work, try yellow pair
http://imgur.com/gksd95B.jpg
Recov servo mean you can not read the platters.
good luck
odedshankar
Postby odedshankar » 06.02.15, 07:00
Thanks Entec,
Meanwhile the heads died so i need to get another donor and re-try.
"Recov servo mean you can not read the platters"
it sounded like heads noise was healthy and like FW corruption?
So i guessed some could be read and maybe some platter damage.
I'll give it another go.
betty
Postby betty » 10.02.15, 06:43
Hai to all
I had a same problem with same model ie Seagate Barracuda Model: ST2000DM001, FW:CC4B
I solved the problem by the help of SHORT PINS with YELLOW Pair which described in link:
Thank u Entec
Betty
Crystal
