I have St500dm002 , Firmware KC45 Hard disk.
Give terminal message
"Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002A185"
F3 T>m0,6,2,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 00256177, File Error 000000D0
F3 T>
Rst 0x10M
ASCII Diag mode
F3 T>i4,1,22
Failed to load overlay 00000004
LED:000000CC FAddr:0028931
Looks like the Defect list has problem. How to resolve it?
Thanks,
St500DM002 DiagError 0000500E Process Defect List Error
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
Re: St500DM002 DiagError 0000500E Process Defect List Error
This problem appear due to damaged P-list or improper defects in P-list. Drive not detect in this condition, some time detects ok.
This error appear when you are trying to regenerate translator.
Solution:
Read SYSTEM file 1B via terminal, remove all defects which has sign C, sign C = G to P transfer.
After that save it and write this system file again via terminal.
power reset
Done.
Solution:
power reset
Done.
Unfortunately the customer has taken back the Hard disk. I can't test further.
Thanks,
Thanks,
Thanks,
Amit Shah
Amit Shah
