freeplay Sentosa issue
rezafarah
Postby rezafarah » 18.11.14, 10:15
hi guy's
i have hdd freeplay Sentosa ST1000LM010 with some problems that i could solve them but i face this error in the utility:
Set Max LBA............................. : No restriction
S.M.A.R.T. status....................... : GOOD
5....................................... : 0 : Reallocated Sector Count
Attrib 190 has value (21) lower than treshold (45)
191..................................... : 0 : G-Sense Error Rate
197..................................... : 0 : Current Pending Sector Count
198..................................... : 0 : Uncorrectable Sector Count
my question is what is this problem and how can i solve it?
thank you.
Nick_TS
Re: freeplay Sentosa issue
Postby Nick_TS » 18.11.14, 15:48
Hello Reza Farah,
Please past here terminal output.
rezafarah
Postby rezafarah » 19.11.14, 09:26
Hello dear Dima
this is the terminal output:
Rst 0x10M
SIM Error 2009
RW Error 00000080
No HOST FIS-ReadyStatusFlags 0002A185
the hdd was working well as i mentioned but just had that error.i tried to write some modules from similar hdd, unfortunately the target hdd went busy!
and now the above terminal commands is appear. after that i tried the method as you load in video material for F3,but wasn't successful.
Nick_TS
Postby Nick_TS » 19.11.14, 16:57
Hello Reza Farah,
Try to follow procedure from this video:
http://www.youtube.com/watch?v=jWjPARPwBdk
rezafarah
Postby rezafarah » 19.11.14, 20:56
dear Dima
thank you for your advice.
as i mentioned in my last post i used this method as it showed in the Video, i saved 4 modules, at last after i save module 93 i could see the whole capacity, i refreshed the module 93 as it showed in the video,regenerate wasn't successful and at last i powered on/off but the drive still busy! :cry:
by the way i have backup from the modules and SA.
