WD BAD PCB USB Device
mscerl
Postby mscerl » 26.10.14, 20:36
Hi there,
After connecting my external WD usb drive it is detected as "WD BAD PCB USB Device"
and no driver is found for "WD Ses USB Device" and the drive is not accessible.
what's wrong with the drive?
Thanks in advance
pclab
Re: WD BAD PCB USB Device
Postby pclab » 28.10.14, 23:39
Try to get a compatible SATA PCB.
Maxim_TS
Postby Maxim_TS » 29.10.14, 16:10
Hello mscerl
Try to solder SATA adapter to USB PCB or use a compatible SATA board.
The list of SATA-USB compatible boards is here:
viewtopic.php?f=35&t=8376
mscerl
Postby mscerl » 29.10.14, 21:55
pclab wrote:Try to get a compatible SATA PCB.
Thank you
mscerl
Postby mscerl » 29.10.14, 21:57
Maxim wrote:Hello mscerl
Thank you
