Test.................................... : Surface verification
ERROR! LBA : 118 784 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 785 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 786 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 787 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 788 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 789 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 790 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 791 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 792 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 793 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 794 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 795 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 796 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 797 Verify sectors ext error HDD Redynes timeout (30)
ERROR! LBA : 118 798 Verify sectors ext error HDD Redynes timeout (30)
Can anyone help me?...
ST3500321CS Bad Sector
Re: ST3500321CS Bad Sector
Did you make translator regen before this?
I just test, yet in translator regen
is there a solution for this case ?. The first step what should I do?
thanks for your reply
Simplest solution is to change reading mode to 'Work with Active Utility'
