ST31000333AS Capacity / max LDA problem
crimestechnosq
Postby crimestechnosq » 23.07.14, 16:03
i have this ST31000333AS 7200.11 of 1tb.
at first it had the LED: CC problem showing this pattern of error:
Rst 0x20M
(P) SATA Reset
LED:000000CC FAddr:0024CDC5
Rst 0x20M
(P) SATA Reset
I used the isolation method, then ran the LED solution from the menu and followed the steps.
Now it reaches ready, but it does not detect Capacity. If i open universal utilities i get these messages:
HDD does not support set max LBA
?????????? ?? ???????????? S.M.A.R.T.
and the ERR ABR lights turns on
Drive model and firmware are recognized correctly, but capacity indicated MB().
Any idea what i should do next?
thanks.
this is what i get in the log window when i power on the disk with seagate F3 architecture utility open
ID Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List))
4 12 Servo Adaptive Parameter File (SAP)
6 66 Read Adaptive Parameters File (RAP)
8 4800
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2B 928 R/W Operating Parameters (translator, etc)
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
35 26 SMART Data
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6020100 33792 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4001000 4096 Servo Adaptive Parameter File (SAP)
602BE00 4096
total 8192
8 10070000 948
A 60A5D44 1024 Seek Profile
12 100D4000 104
13 60B0F78 544 Dependent Zone Table for User Area
14 60B1198 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60B02A0 3288 Dependent Zone Group Tables for User Area
1C 60B0160 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020310 2320 Zone Format Parameters File
RAM:
ID MemOffs Len
2 60201F0 288 Zone Table
602BE00 4096
total 8192
6 203244 40996 Servo Flaw Table
8 10070000 948
12 100D4000 104
16 6020100 32 Drive Configuration Table
17 6021F20 1744 Temperature Control Configuration
1F 6144690 1224 RW working user preamp table
20 6144B58 72 RW working system preamp table
Collecting DT Infos completed
Detecting Phys Sct Size...
Re: ST31000333AS Capacity / max LDA problem
Postby AJ2008 » 23.07.14, 16:39
This is model without NRG issues so you can probably solve this with basic translator recovery command
(m0,6,3,,,,,22)
or using automated translator regen option in utility
crimestechnosq
Postby crimestechnosq » 23.07.14, 20:47
thanks for reply, i will look into it.
