Got this drive that can't ID...
After power on I get this:
Techno On............................... : Drive is not ready
Zone table.............................. : Zone table read error; Drive is not ready
G-List reading error.................... : G-List read error; Drive is not ready
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE ,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D 6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
The drive tries to calibrate (some very low noises) and sometimes can get Ready, other times, stay Busy.
Can this be only the G-list error?
I have tried to clean it, but I always get the drive Busy....
Thank You
Toshiba MQ01ABD050 BSY
Re: Toshiba MQ01ABD050 BSY
i used this method for so many times and it was successful:
inter the utility,select the right model. wait to see drd and dsc,it may take 5 to 10 minute in some cases!
after that use 'edit hdd ID', if you see the menu so click ok, if not repeat this again(on/off the hdd /wait/ edit hdd ID), for me must of times this method is successful.
if the hdd ID was successful, clear smart and Glist,in edit defect list,backup the Plist, and then at last clear the Plist.
on/off the power and inter the model again. every thing will be good.
