Hi Folks,
Hope all is well your side of the world
I need your assistance in a case i've got - please see images:
https://dl.dropboxusercontent.com/u/495 ... ve-img.rar
Drive was inside an XP machine and stopped working, it clicked when i got it.
I tried hot swap with an exact donor drive to try and read the FW but during re-calibration the donor PCB also clicked on the patient drive so i assumed heads are bad.
I opened the drive in a clean room and haven't seen any obvious damage to platters or heads.
I swapped the heads from the donor drive but the behavior stayed the same, still clicks.
Any ideas or can you assist here?
Please advise,
WD 80GB unknown issue
- GuideRecovery
Re: WD 80GB unknown issue
swap back heads to patient drive and see if they are ok ?
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
- odedshankar
i did swapped them back and aligned the screws and it woks good on donor but not on patient.
Probably micro scratches on the platters.
Probably your drive is pre-Royl and has some level of complications regarding alignment?
- odedshankar
yes looks like it, i swapped heads and try to align - no luck with this one
