I have a 7200.12 that spins up normally, but does not become ready (stays BSY)
when I spin it up, Terminal reports
Rst 0x20M
I can read the P-List, but cannot get to drive ID etc.
Does anyone have a solution to this? It seems that there are quite a lot of these problems, but no one seems to have found a solutuion.
I tried shorting the read points, but the drive clicks like it normally would, stops spinning but is still BSY.
No HOST FIS-ReadyStatusFlags 2002A1A5
Re: No HOST FIS-ReadyStatusFlags 2002A1A5
So after that the drive goes ready or BSY?
You have terminal access right?
No HOST FIS-ReadyStatusFlags is a problem with some of FIDs, another words - System Files.
I have same drive with same issue ... how to fix system file ..... or nay solution ?
- regedit_hdd
Try do:
/2
Z
U
m0,2,2,,,,,22
/1
N1
then reset power
/2
Z
U
m0,2,2,,,,,22
/1
N1
then reset power
regedit_hdd wrote:Try do:
/2
Z
U
m0,2,2,,,,,22
/1
N1
then reset power
First, try 'V40' to check for NRG defects...
There is a fix for this error under Work with ROM, it wont resolve any failure but will allow DRDY state and here you may have options such as Eslip mode and work via utility etc but ideally you want to solve the actual fault and for this probably it is related to translator but you really need to be sure you know what you are doing and you know both what commands you enter actually do, and any implications of entering them.
