I have Seagate 2Tb hdd st2000dm001 Remains busy. Motor spin ok and running, No clicking noise. Check with the other pcb but problem remains same.
Terminal output.
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0026[0x00026F7C][0x000270DF][0x000270DF]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
What is the mean by 0000yW preampfault?
Seagate st2000dm001 2TB - preampfaultstatus =0000YW
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
Re: Seagate st2000dm001 2TB - preampfaultstatus =0000YW
Hi Amit,
have you found a solution for this problem?
I have the same problem with same model after head stack replacement - terminal output as Amit posted.
Anybody else with a solution?
I doubt in Rom corruption or Head adaptives. What is the usage of Block-1 and Block-2 option in rom for SAP+RAP+IAP Modules change in Ram?
Thanks,
Amit Shah
Amit Shah
Arihant wrote:I doubt in Rom corruption or Head adaptives. What is the usage of Block-1 and Block-2 option in rom for SAP+RAP+IAP Modules change in Ram?
Just wash the PCB and do short pointing for access terminal
already did on 2 Drives with same preampfault error.
I have check with other pcb (rom Swapped).
Still same problem.
Is any other check points ?
Thanks,
Still same problem.
Thanks,
Thanks,
Amit Shah
Amit Shah
