Build a heads map starting at the end?
gterry
Postby gterry » 28.04.14, 22:50
I have an 500gb Hitachi HTS5450B series. It has four heads and lets me build a heads map up to 234000000 sectors then times out. Using that heads map and disabling head 0 (its bad) I can successfully image the rest of the remaining three good heads up to the 234000000 mark then it I guess looses the map and starts using head 0 again and screwing up. Im thinking there must be a bad area around that mark. Without putting a new set of heads in, is there a way to run the head map procedure backwards from 976773167 to that 234000000 mark so that I can run the imaging backwards and disable head 0?
Nick_TS
Re: Build a heads map starting at the end?
Postby Nick_TS » 11.07.14, 17:05
Hello gterry,
In task parameters in Data Extractor select back direction, and define start and final sectors.
Also you can try to initialize translator in RAM
Return to “Data Extractor”
