Terminal Output
betty
Terminal Output
Postby betty » 14.02.14, 06:47
Hai All,
Any body can explain the following questions:
1.What does mean by Terminal Output (F3>)
2. If we are able to Access the Terminal By Ctrl+Z, :
a) what kind of level we succeed and what kind of task can be do.
3. If we are not able to Access the Terminal by Ctrl+Z
a) why we are not able to access the Terminal ?
b) what kind of level we can not access?
4. What are the Terminal Commands?
Betty
Crystal
Re: Terminal Output
Postby AJ2008 » 14.02.14, 09:17
betty wrote:Hai All,
Betty
Crystal
Terminal output refers to any data the drive sends through its serial port, this includes information on its health, error codes and is much like a startup log for the drive. When you can reach a prompt with CTRL+Z it means the drive is ready to accept commands over serial port. Commands such as clearing smart can be executed here. Often many complex problems can be solved through serial only. In some cases the terminal is locked, such as in FDE drives or models with custom or OEM firmware. There are ways to reach it such as short circuit, but on times it can be quite tricky. Other cases involve a terminal output, but no option to input. Again, there are methods to reach this involving short circuit of read channels. There are many many terminal commands, many are destructive or can result in data loss. Also, many you will never need. Is best not to try to learn them all, but learn what you need and what is relevant. When you receive a case with terminal issues you can post here and this is how you can learn more, but you should be very careful when learning with terminal, always practice on a dummy drive until you have the right knowledge and experience.
betty
Re: Terminal Output
Postby betty » 14.02.14, 14:50
Thanks a lot AJ2008....
Betty
Crystal
Return to “Data Extractor”
Users browsing this forum: davidswa1 and 11 guests
