I have been meaning to ask this for a long time. But now it really need a solution.
When I am doing Data Copy in D.E., and before I start, or when I hit a slowdown,
it is better to work from a heads map and image the drive one head at a time.
But for several weeks now, on many kinds of drives, this button in D.E. does NOTHING.
Just click and nothing happens.
Did I change a setting somewhere?
I just installed the new version of PC3KUDMA software - no change.
A simple answer for AJ I think..
-Drew
Building Heads Map no longer works
- RescueDRL@gmail.com
- New user
Re: Building Heads Map no longer works
It should work fine. Silly question, but is the utility open in PC3000 while you run headmap in DE? Headmapping is taken from things like zone table so utility needs to be opened to read it well.
- New user
DOH! No, it was not. Now it works.
