wd20earx-32pasb0 problem in detect
NSRGroup
Postby NSRGroup » 16.01.14, 15:24
hi
i have a hdd wd
WD20EARX-32PASB0 AFTER POWER ON
motor spinup normal sound no clik clik after 2 second DRD DSC led green but after run utility (read hdd identification) BSY DRD DSC led green and stay busy
i managed for block sa access method , i saved rom and rom modules but i d do'nt have loader for this drive
in below log in kernel mode
Techno mode key
ROM version............................. : 27.54R
ROM generation.......................... : 27.54R
Link table version...................... : 0C.05.
Consolidated ROM version................ : 00270054
ROM Modules:
Modules directory address............... : 377 592
SA regions address...................... : shifted
SA defects assigned..................... : 2
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00270054
what that nex step?
any one have this loader?
with thanks
hamid bidrang
rezafarah
Re: wd20earx-32pasb0 problem in detect
Postby rezafarah » 16.01.14, 16:46
what is the model?!
NSRGroup
Postby NSRGroup » 17.01.14, 10:33
rezafarah wrote:what is the model?!
good questions!
wd20ears-32pasb0
Postby AJ2008 » 17.01.14, 10:41
Try to short read channels, then enter SPT and try to get access to native loader by ID. Probably loader will not work on this model, but if you can reach SA by ID you can try to find problem.
NSRGroup
Postby NSRGroup » 17.01.14, 10:48
AJ2008 wrote:Try to short read channels, then enter SPT and try to get access to native loader by ID. Probably loader will not work on this model, but if you can reach SA by ID you can try to find problem.
thanks for answer
for short read channel
how i can find read channel point? is the same for seagate hdd?
in normal mode or in block sa acces
with thanks
hamid bidrang
