Toshiba MK6465GSX CP error
mscerl
Postby mscerl » 16.11.13, 21:54
Hi there,
while trying to add the defects to the p-list i receive the following error:
"CP Writing error; Device Error Detected 51/19 (AMN;<bit3>;INF"
what's the problem?
Filipp_TS
Re: Toshiba MK6465GSX CP error
Postby Filipp_TS » 21.12.13, 15:54
Hello mscerl,
This is problem of Heads, likely it can't write data.
All defects writing in to modules that placed at platters surface.
Also, AMN-led mean, that head(s) have problem.
Need to check hda inside.
mscerl
Postby mscerl » 21.12.13, 16:57
Filipp wrote:Hello mscerl,
Thanks for the reply
houman_2h
Postby houman_2h » 31.12.13, 02:26
Sometime this isnt problem of heads. you should edit plist before add .
Return to “Toshiba native”
