I have one working hard disk wd10eucx-73yz1y0. I have taken Full SA Backup. I have backup of all the tracks, Rom and Modules.
By Mistake the hdd is module -11 is over Written with other. Not the hdd is not detecting. HDD-ID does not shows model name, serial, size or firmware.
Log File
Techno mode key
Heads number............................ : 3
ROM version............................. : 51.22A
ROM generation.......................... : 51.22A
Link table version...................... : 00.09.
Consolidated ROM version................ : 00510022
ROM Modules:
Modules directory address............... : 382 448
SA defects assigned..................... : 1
Heads number in use..................... : 3
Heads map............................... : 0,1,3
ROM Firmware version.................... : 00510022
I have not other donor hdd so hot-swap is not possible.
Thanks,
Wd10eucx-73yz1y0 Module 11 corrupted
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
Re: Wd10eucx-73yz1y0 Module 11 corrupted
I have recieved the donor & finish by hot swap.
Thanks,
Thanks,
Thanks,
Amit Shah
Amit Shah
