Hello ,
Samsung HM161GI 160GB remains BSY following is terminal output when powered on
*PA VID=0007 PN=0000 Rev=0004
ChipRev = 63B0
U
S_0Shock Sensor Circuit Enabled
SO_1
IS=1
CLA #36/56
Handoff RPM=662
SPOK
mS1 00000003
A1O=111 A1G=443
O=512 S=1
SK C: 5082 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x17
ResoTable Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Loaded. Rev:0x02
Zh:0000005C Curr:00000098
Zh:0000005C Curr:000000B2
Zh:0000005C Curr:000000AF
Zh:0000005C Curr:00000092
Zh:0000005C Curr:000000AE
Zh:0000005C Curr:00000090
Zh:0000005C Curr:000000D4
Zh:0000005C Curr:00000099
Zh:0000005C Curr:00000091
Zh:0000005C Curr:000000B1
Zh:0000005C Curr:000000AD
Zh:0000005C Curr:0000008F
Zh:0000005C Curr:0000009B
Zh:0000005C Curr:000000BB
Zh:0000005C Curr:000000D2
| 19 | RLIST | 2 | 0 | 468 | 1140 |
Reading Serial Num Pass
Up MC
PwrOn RRO1x @ H0
Table) cos = -684800, sin = 91648
Coeff) cos = 50292, sin = -226614
DiskSlip : 63 [SrvTrk]
DiskSlip : 60 [SrvTrk]
TgtCyl: 842
Hd: 0 Zn: 0 Avg.: 7
TgtCyl: 171888
Hd: 0 Zn: 1 Avg.: 938
SVCAL(0080,0000)-->PASS
Zh:0000005C Curr:0000007B
Zh:0000005C Curr:00000080
Zh:0000005C Curr:00000086
Zh:0000005C Curr:00000082
Zh:0000005C Curr:000000A1
Zh:0000005C Curr:0000007D
Zh:0000005C Curr:00000084
Zh:0000005C Curr:0000007F
Zh:0000005C Curr:000000A0
Zh:0000005C Curr:00000083
Zh:0000005C Curr:000000B0
| 244 | ZONHEAL2 | 41 | 0 | 0 | 1140 |
InitAtwHZh:0000005C Curr:00000081
Zh:0000005C Curr:000000CC
Zh:0000005C Curr:00000088
Zh:0000005C Curr:000000CE
Zh:0000005C Curr:0000007E
Zh:0000005C Curr:0000008C
Zh:0000005C Curr:0000008D
Zh:0000005C Curr:00000085
Zh:0000005C Curr:000000CF
| 167 | DRM | 27 | 0 | 0 | 1140 |
RecordValid Fail : 0107647D 0107E41D
EPOK
SoUL!
PK_4 C: 8496 H:0
Software unloading!
PK_4 C: 8496 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
I tried to clean contacts & also tried to clear A list but
Techno mode error; unexpected error: Command PIO data in error: HDD Redynes timeout (10000)
Test completed
Test completed
please guide
Samsung HM161GI BSY
Moderator: Garry_TS
- Takanashi_Hina
Re: Samsung HM161GI BSY
Did you try to issue the "LE" command on termnal to gain SA access ?
Read here :
viewtopic.php?f=33&t=7454
Read here :
Thanks for you reply.
I tried this,it works but if i am trying to make image after some time (1-2 mins ) Hdd again goes in Bsy state again .
After that it repeats issue i cant able to make image.
If i tried after keeping hdd off for some time again repeats procedure then it copies image for 1-2 mins but same issue.
kindly help
Manish
kindly help
Manish
Did you try to change reading mode and adjust parameters such as wait times for reading? Maybe this will help.
- Takanashi_Hina
My guess is that the drive starts to read the platters and can't do so, because of media defects. So it starts to put them on A-List until it overflows. When the drive stay stuck because it can't read you power it off and on and the A-List will be damaged and cause the LED 1A04 error.
If you have a DDI you can try to fix the drive with PC3K and as soon as you clear the A-List with UDMA you just power off the drive, plug it to the DDI and start REVERSE cloning.
If the drive gets "stuck" again check with hex editor if you have copied any data at all and report back.
Maybe one head is gone and when drive starts reading with that head will consider the platter as defected (can't read) and add the sectors to A-list. If you can clone from the end of the drive to the start and get a considerable amount of data then the problem might be a patch of bad sectors/track on platter. If you can't clone from reverse but you get "some" data one head might be causing the issue. If you don't get any data at all even with reverse cloning the problem will be elsewhere ....
Takanashi_Hina & AJ2008 Thanks alot
i tried
But not worked but after that i pluged it again to pc3k and started reverse imaging .worked and made image.
Thanks alot for your valuable help
i tried
- Takanashi_Hina
alphapune wrote:Takanashi_Hina & AJ2008 Thanks alot
i tried
Cool !
Glad it worked at the end !
Were you able to get all the data ? Did you use DDI4 to do the reverse imaging on the 2nd time ?
Regards.
Yes got all data
i used pc3k portable for reverse imaging .
- Takanashi_Hina
alphapune wrote:Yes got all data
Ok !
Nice to know that !
Regards.
