ROM for Samsung HM100UI/UZ4 P/N: C5072
mekaniq
Postby mekaniq » 20.11.13, 14:22
I need ROM for Samsung HM100UI/UZ4 P/N: C5072
Best Regards,
Cem Gunal
cemgunal@gmail.com
Re: ROM for Samsung HM100UI/UZ4 P/N: C5072
Postby AJ2008 » 20.11.13, 16:08
Damage to ROM on this model is very common. Sometimes matching the date code on the label will get you a donor PCB with compatible ROM version, but for me I prefer to make HotSwap and write both donor overlay modules to patient SA (on all copies) and then you can reach data with donor PCB.
mekaniq
Postby mekaniq » 20.11.13, 16:27
Thank you AJ2008, will try that method. To be exact, which ones are overlay modules?
Postby AJ2008 » 20.11.13, 16:28
19 + 73
