hi to all
I have WD 2.5" sata
after connecting it to pc3000 , some part of the statements it shows are as follow:
ROM Modules:
SA defects assigned..................... : 2
Heads number............................ : 3
Heads number in use..................... : 3
Heads map............................... : 1,2,3
ROM Firmware version.................... : 0010000T
now i have 2 questions :
1) the line in red color , what is it ? should i repair anything or it got ok ??
2) when i tried to do HEAD TEST with PC3000 , although the hdd has 3 heads but heads no.1 and 2 were checked to test , the head no.3 had no checkmark to test , is there anything wrong with head no. 3 ?
this is also the result of head test :
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 1,2,3
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Error W : 36
any suggestion ?
best regards
Mojtaba Morady
what is this Error ?
- mojimorady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: what is this Error ?
First of all, what's you goal, data recovery?
- mojimorady
hello friend
The data were recovered without any problem
I just wanted to know more about it .
I tried to repair the H.D.D but I could not .
just it
best regards
just it
best regards
Mojtaba Morady
for repairing , simply you you remove head no 3 from test menu
- mojimorady
Dear Waleed
just for test should I do this job or forever ?
Mojtaba Morady
