ST3000DM001
Nadpc3k
ST3000DM001
Postby Nadpc3k » 30.08.13, 16:30
I got ST3000DM001 3TB drive. spin ok and recognize in the Pc3k... after a while /// in terminal give errors below ...
Write Error - C4090081
(DOS) Write Failure Reallocation started.
(DOS) AutoWriteReallocationEnabled and Reallocation Request Issued. !00000080
(DOS) WriteFailureReallocateLBARequest is executed successfully.
(DOS) Write Error - C4090081
Anybody have some solution for this ?
dmarques
Re: ST3000DM001
Postby dmarques » 30.08.13, 17:26
Can you save SA?
Can you access sectors?
Nadpc3k
Re: ST3000DM001
Postby Nadpc3k » 03.09.13, 17:42
can not access sector , and SA
dmarques
Re: ST3000DM001
Postby dmarques » 04.09.13, 10:09
But can you even access terminal?
Nick_TS
Re: ST3000DM001
Postby Nick_TS » 10.09.13, 14:25
On the most drives reading channel line is crossed with an element,
so it is easy to find two lines that go from pads to CPU on your drive board.
You should short the contacts with a pincers when holding a paperclip with it.
Also, the moment to short is before 2nd recalibration.
When shorted properly, drive will start to click and then it will stop.
At the same time press ctrl-z within terminal window and check if T> is there.
Re: ST3000DM001
Postby AJ2008 » 12.09.13, 12:06
Often, if you are patient you will reach some access to SA and sometimes data. At this time you can disable any pending parameters.
If not, then follow Dima's advice and try to find short points.
