WD10EZEX-00ZF5A0/DCM EANNHT2CHB /DCX 4Z04F0356 1TB HDD HAVING ISSUE GETTING IN DRD DSC STATE BUT NOT SHOWING DETAILS IN WD UTILITY MDL/SN/FW (aLL NOT GETTING DETECTED)/CAPACITY SHOWS MB ()
WHEN I POWER ON HDD INITIALLY MAKING SLIGHT HEAD STUCKING NOISE AND SPIN DOWN
Techno mode key
ROM version............................. : 45.AAF
ROM generation.......................... : 45.AAF
Link table version...................... : E8.02.
Consolidated ROM version................ : 004500AA
ROM Modules:
Modules directory address............... : 124 525
ROM Firmware version.................... : 004500AA
Code type to check...................... : TypeN
Code addr............................... : FFE00000
Code size............................... : 327681
Code reading............................ : RAM Range FFE00000 (050001) reading error Device Error Detected: "VSCE KEY SECTOR MUST PRECEED DATA XFER REQUEST"
No HDD RAM access, LDR upload is recomended
IF TRYING TO LOAD LDR MANUALLY GIVES ERROR
RAM RANGE....VSCE KEY SECTOR MUST PRECEED
ALSO I TRIED http://ts.acelab.eu.com/index.php?/ ... to-modules
BUT SAME ERROR UNABLE TO LOAD ldr
ANY SUGGETIONS ,
THANKS
WD10EZEX
