I have a seagate st2000dl001 , and Firmware CC98, When i view sectors after 2000000 i got the unreadable sectors,
Anyone can help in this,
best reg.
gh. farjad
unreadable sectors on seagate st2000dl001
Re: unreadable sectors on seagate st2000dl001
Did you rebuild translator before trying to get access?
no i dont rebuild translator
Probably someone has rebuilt translator and NRG is not right, or it has some level of pending bug. Do you see any information in Terminal field?
No, it`s empty
You are sure there is no terminal output at all?
Yes of course.
But you get "T>" after pressing CTRL+Z?
thanks, that`s write
the massege is
ASCII Diag mode
F3 T>
Spinning Down
Spin Down Complete
Elapsed Time 14.516 secs
Delaying 5000 msec
Jumping to Power On Resetÿ
Rst 0x20M
(P) SATA Reset
RAW OFF
PASS
the massege is
ASCII Diag mode
F3 T>
Spinning Down
Spin Down Complete
Delaying 5000 msec
Rst 0x20M
(P) SATA Reset
RAW OFF
PASS
With terminal connected, at your task in DE select 'Work with active utility' then select 'No' at the next prompt. Now try to read sectors .
Please Tell us more about it ( at your task in DE select 'Work with active utility' ) or how do it?
Select 'Task Parameters' -> 'Command to Read' -> 'Read from Active PC3000 utiltiy'.
Try to increase Terminal timeout.
