WD10EARS-00MVWB1 FW Vers: 00200076 (20.76E) LDR needed
mee
Postby mee » 13.06.12, 11:33
I need loader for WD10EARS-00MVWB1 FW Vers: 00200076
The drive is from family Sadle G6
Heads map............................... : 0,1,5,7
ROM Firmware version.................... : 00200076
Thank you in advance
Re: WD10EARS-00MVWB1 FW Vers: 00200076 (20.76E) LDR needed
Postby ACE_Admin » 13.06.12, 15:07
Haven't got the exact one, anyway I have 00200085. Here is 11th file attached. Try my loader if it will work with your drive.
If you like I can provide you whole SA for this drive.
11.rar
(331.06 KiB) Downloaded 377 times
mee
Postby mee » 14.06.12, 05:23
I will try to use this.Thank you so much Roustam.
houman_2h
Postby houman_2h » 06.07.13, 01:02
Postby AJ2008 » 08.07.13, 10:11
Are you sure a loader will help with this model?
what symptoms does it show?
