WD20EARS-00MVWB0 F/W 0024000C Loader
drmilos
Postby drmilos » 05.06.13, 11:46
I need a loader for WD20EARS-00MVWB0 F/W 0024000C (not sure that it will resolve my problem but it's a good start, will keep you posted)
RAM:
ROM:
ROM version............................. : 24.0CB
ROM generation.......................... : 24.0CB
Link table version...................... : 0B.21.
Consolidated ROM version................ : 0024000C
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 656 (24)
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 0024000C
Re: WD20EARS-00MVWB0 F/W 0024000C Loader
Postby AJ2008 » 05.06.13, 12:16
Loading LDR wont work at Sadle, HDD will make a reset during loading and LDR cleared from RAM.
What problems has it got?
drmilos
Postby drmilos » 05.06.13, 14:15
Those are exactly the symptoms I had, and I thought I have the wrong loader.
Operator problem again, I uploaded the wrong ROM image, all good now, thank you.
