FreePlay Sim Error 1009
Arihant
Postby Arihant » 22.05.13, 13:28
I have one 1tb Segate free play hard disk. It is detecting perfectly while utility start.
Rst 0x10M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
127537 99999999 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127547 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127559 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127569 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127581 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127591 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127604 13 9 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127614 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127626 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127636 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127648 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127658 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127670 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127680 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127693 13 9 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127703 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127715 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127725 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127737 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127747 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127759 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127769 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127782 13 9 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127792 10 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127804 12 9 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127814 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127826 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127836 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127848 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127858 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
127870 12 10 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000002FD8A L 00000001 BO 000000 BES 0039100.003913F.0039100
127880 10 11 02 005041 000000 1 00000080 XFR WR SYS LBA B 00000006CB7D L 00000001 BO 000000 BES 0039100.003913F.0039100
ASCII Diag mode
F3 T>V4
Reassigned Sectors List
Entries: 0000, Alts: 0000, Removed: 0000, Pending: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs Status BBM Mask
F3 T>V40
DiagError 00000007
translator regeneration, clear smart etc. command working perfectly. I can't access the data. Even can't access dt modules.
Utility Status shows the
Requesting FW Pkg ver ........ SNE10C.CCD9.AQ0A6C.CC94
Detecting Phys Sct Size...
Error obtaining Phys Sect Size!
Error starting command "En Tech" (ABR)
Detecting Max Head number...
Phys. heads............................. : Error
Error starting command "GDL" (ABR)
Tech Key...
HOw to recover the data?
Thanks,
Amit shah
Thanks,
Amit Shah
Arihant Data Recovery, India
Re: FreePlay Sim Error 1009
Postby AJ2008 » 22.05.13, 13:57
Does modules table load ok when you enter utility? Maybe you have some relocation issues, sort them and then check if HDD is a little more accessible.
Did you check V40 before making translator regen?
Arihant
Postby Arihant » 24.05.13, 07:37
AJ2008 wrote:Does modules table load ok when you enter utility? Maybe you have some relocation issues, sort them and then check if HDD is a little more accessible.
Module table is not loaded while entering in utility. It Gives Tech Key...
Error starting command "En Tech" (ABR) Error. How to solve the relocation issue?
HDD family detecting...
Family ID: 55
Selected family................................... : 55, Sentosa
Model by ID....................................... : ST1000LM002-9VQ14L
Loading default settings!
Then press OK!
Tech Key...
Thanks,
Amit Shah
Arihant
Postby Arihant » 24.05.13, 08:24
I can read All ID Pages Sucessfully.
Reading HDD ID pages list...
Reading HDD ID pages...
ID Page 00............................................................ : Ok
ID Page 01............................................................ : Ok
ID Page 02............................................................ : Ok
ID Page 03............................................................ : Ok
ID Page 04............................................................ : Ok
ID Page 08............................................................ : Ok
ID Page 09............................................................ : Ok
ID Page 0A............................................................ : Ok
ID Page 0B............................................................ : Ok
ID Page 0C............................................................ : Ok
ID Page 0D............................................................ : Ok
ID Page 0E............................................................ : Ok
ID Page 0F............................................................ : Ok
Thanks,
Thanks,
Amit Shah
Arihant
Postby Arihant » 28.05.13, 06:23
is any solution available?
Thanks,
Thanks,
Amit Shah
houman_2h
Postby houman_2h » 05.07.13, 15:48
Whats the solution ?
Any advice ? :!:
Arihant
Postby Arihant » 08.07.13, 15:56
Still searching solution.
Thanks,
Amit Shah
ray1006
Postby ray1006 » 28.08.13, 16:34
Hello Room
First of all Thank TS
TS solved it.
you can see the Solution in
http://ts.acelab.eu.com/index.php?/ ... a-sys-file
may it can not read the sys file , no problem just download the sys file and Load it ( it is full zero ) and click on " write to HDD" .
God bless TS
Arihant
Postby Arihant » 29.08.13, 07:09
Thanks,
Amit Shah
houman_2h
Postby houman_2h » 30.08.13, 15:45
:P :P :P I recovery my hard with this method
