I have st2000dl003
spins up sounds great,
recalibrates - sounds like its totally ready
stays BSY.
I can get terminal.
cant read DT, or phys sectsor size.
turned off idle activities.
init smart fails
here is startup, ^L and N1 results...
whats the solution???
Rst 0x40M
MC Internal LPC ProcessRW subfile error 2008RW subfile error 2008
SIM Error 2008
RW Error 00000080
User Data Base 00991D48
MCMainPOR: Start:
MCInitialize: Start: Buffer Words VBM: 00000210
MCMainPOR: EXCEPTION: MC Init Fail. Feature disabled.
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = E59FF018
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000F018
MCMainPOR: MCStateFlags = 00000000
MCMainPOR: EXCEPTION: POR Failed General PASS
No HOST FIS-ReadyStatusFlags 0002A1A5
ASCII Diag mode
F3 T>
Banshee Bogart, RAP17, add 6k SAP csys 4K QNC MC
Product FamilyId: 4F, MemberId: 02
HDA SN: 5YD0YG2K, RPM: 5939, Wedges: 1F8, Heads: 6, OrigHeads: 6, Lbas: 00001D326C40, PreampType: A8 15
PCBA SN: 0000M118LBYW, Controller: BANSHEEST_2_0(8000)(4-00-0-0), Channel: Unknown, PowerAsic: MCKINLEY DESKTOP LITE Rev 91, BufferBytes: 4000000
Package Version: BGD15D.CCD3.BZ09B4., Package P/N: 100656017, Package Global ID: 00188399,
Package Build Date: 01/10/2011, Package Build Time: 15:26:50, Package CFW Version: BGD1.CCD3.00322720.00188399,
Package SFW1 Version: D556, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 01101526, CustomerRel: CC32, Changelist: 00322720, ProdType: BGD1.CCD3, Date: 01/10/2011, Time: 152650, UserId: 00188399
Servo FW Rev: D556
RAP FW Implementation Key: 11, Format Rev: 0302, Contents Rev: BB 03 09 00
Features:
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 compiled off
F3 T>/1
F3 1>N1
Init SMART Fail
Rst 0x40M
LED:000000BD FAddr:00004C51
st2000dl003 - No HOST FIS-ReadyStatusFlags 0002A1A5
skype: wayne_horner
Alandata Data Recovery
Re: st2000dl003 - No HOST FIS-ReadyStatusFlags 0002A1A5
MCMainPOR: Start:
MC stays for media cache and you should turn it off.
Media cahce option is located within flags of "Edit hdd id" window.
So, if you can reach it from Tests->Service information->Work with Sa->Edit hdd ID , then turn it off, press ok and save the parameters.
If not, you can open up Sys.Files tab from Tools->Utility extentions->HDD Resouces view and edit and read next sys. file that contains
information about these flags: vol. 0x03 sys file 0x0093 copy 0x00
To edit the flags find plugins menu on the right side of top toolbar, and open SNP plugin. It will show you same window you can see when opening "Edit hdd ID".
Turn off mediacache option, save the changes and make sure they were applied(by reading this sys.file again).
Then restart drive and check what will happen.
ok disabled everything close to media cache
X_show additional diag
__offline defect
__deferred defect
__auto reallocate reading ( & writeing )
X_Disalble IDLE activities
__offline scanning
X_disable prefecch
X_reading cache is disabled
X_disable look-ahead reading
now I get this on startup and it stays bsy
Rst 0x40M
SIM Error 2008
RW Error 00000080
MCMainPOR: Start:
__offline defect
__deferred defect
__offline scanning
X_disable prefecch
Rst 0x40M
SIM Error 2008
RW Error 00000080
MCMainPOR: Start:
skype: wayne_horner
- datasolution
- New user
Roustam wrote:MCMainPOR: Start:
ACTUALLY I AM UNABLE TO FIND THIS PLUG IN MENU ON THE RIGHT SIDE OF TOP TOOLBAR IF U CAN EXPLAIN VIA PICTURE OR SOMETHING MORE DEEPER GUIDE THAN IT IS GREATFULL TO ME.
THANKS WAITING FOR REPLY.
