Seeking Solution: ST2000DL003 - BSY AND PCB alone not answar
brre
Postby brre » 24.10.12, 20:39
Hi guys.
1 - I have a Seagate ST2000DL003, the hdd makes the SERVO (is possible to listen), this hdd stay busy all the time.
2 - If I isolate the motor, the terminal simply do not respond
The Terminal:
MC Internal LPC Process
FAIL Op=0900 Resp=0005
(P) SATA Reset
SIM Error 1009
RW Error 00000080
User Data Base 00991B20
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A58C 4011869C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 000022AC
[RSRS] 1EFE
Reconstruction: Completed 0: MCMT Was Valid, HeadPtr was unwritten
Rst 0x40M
LED:000000BD FAddr:00005652
Img of PCB:
1
tea
Re: Seeking Solution: ST2000DL003 - BSY AND PCB alone not an
Postby tea » 24.10.12, 21:51
me too
I have two hard disk . how to repair it ?
[2012/9/25 15:49:20] ST2000DM001
tea
Postby tea » 24.10.12, 21:54
I guess cp2102
maybe need change
brre
Postby brre » 25.10.12, 14:37
tea wrote:me too
Good question!.
But I do not find the solution, I´m seeking...
brre
Postby brre » 30.10.12, 13:05
tea wrote:I guess cp2102
maybe need change
Hi Tea, In my case, I don´t reach the modules/CP (cp2102)...
The terminal don´t respond of commands...
I don´t know if is the pcb, or if he have a problem in S.A...
I´m looking for a donor, for some test... maybe find something promising.
Best Regards.
Brre
avenger-fr
Postby avenger-fr » 02.11.12, 18:26
I have a similar case ... ST1500DL003
BSY but sounds OK and in terminal (my disk have some diferences with your's but result is the same : LED BD !) :
Rst 0x40M
(P) SATA Reset
User Data Base 009915A8
MCMainPOR: Start:
MC Seg Disc and Cache Nodes: 4011A624 40118734
Nonvolatile MCMT sequence number 00004CEA
[RSRS] 22BC
ProcessRWError -Read- at LBA 0012FEE5 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0012FEE5!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
ReadFooters (Forward): Segment 22BC StartLBA 0097F680 Starting Footer LBA 0097F8D8
SeqNum 00004CEB TotalUserBlocks 0228
Footer Status = 0001
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 00004CEB FFFFFFFF
Reconstruction: ProcessIncompletelyWrittenSegment
Adds LBA/Len
005E0047/0008 005F24CF/0008 00600C1F/0008 00600EDF/0008 00600FDF/0008 006010FF/0008 00601117/0008 0060119F/0008 00601227/0008 0060127F/0008 0060128F/0010 006012A7/0008 00601317/0008 00601397/0008 006013E7/0008 006014AF/0008 0060153F/0008 00601577/0008 006015B7/0008 006015E7/0008 0060160F/0008 006016E7/0018 0060183F/0008 006018E7/0010 006019AF/0008 00601A17/0008 00601C47/0010 00601C5F/0008 00601EC7/0008 0060261F/0008 0060271F/0008 00602C1F/0008 00602D4F/0008 00602F77/0008 0060494F/0008 00604F57/0008 00604FF7/0008 0060500F/0008 0060509F/0008 006050FF/0008 006078AF/0008 00607A57/0008 00607DEF/0010 00608FFF/0008 0060A62F/0008 0060A8FF/0008 0060BABF/0008 0060BCE7/0008 0060BE5F/0008 0060BE6F/0008 0060BECF/0008 0060C09F/0008 0060C12F/0008 00619A6F/0008 00619B07/0008 2C8B092F/0010 2C8B099F/0010 2C8B0A1F/0010 2C8B0B1F/0010
Add Count 0000003B
Rems LBA/Len
Reconstruction: Last Chance
Rst 0x40M
LED:000000BD FAddr:00007E05
Anybody have a suggest to make ?
