when i put power cable the hdd work normally but when i but power and sata cable Hdd make noise .
and this erorr show in
this videou link
http://www.youtube.com/watch?v=iTdoJL-4 ... e=youtu.be
i need helpe
Re: i need helpe
Try a new PCB with NVRAM transfer
Re: i need helpe
pc_fox2009 wrote:when i put power cable the hdd work normally but when i but power and sata cable Hdd make noise .
This is because HDD does not start initialise until Data cable is connected.
Pcimage is right, you should try donor PCB with NVRAM transferred before you attempt any other works.
