WD6400BPVT SMART CLEARANCE PROBLEM
hamidsamet
Postby hamidsamet » 02.10.12, 11:22
dear guru
accept my regards
i have a hdd in the following specification :
WD6400BPVT-60HXZT1
640GB
in the "UNIVERSAL UTILITY" window i have following reports :
ATTENTION! Device has 8 logical sectors per physical sector.
HDD does not support set max LBA
Attrib 184 has value (95) lower than treshold (97)
user data is not important,i just want repair the hdd
i did the followings to fix smart problem, but nothing happened :
1. clear smart
2. erase p-list and g-list and relo-list
3.in the result of "SA STRUCTURE TEST" everything is ok
now i am confused how to fix smart problem
lots of appreciation for all your helps in advance
Best Wishes
H.Samet
