I'm searching the shorting points for seagate pcb 100617465 on a ST2000DL001 drive. Isolating motor contacts doesn't work
thanks
François
shorting points
Re: shorting points
Post clear image of the pcb here
Re: shorting points
This is the pcb photo.
thanks
thanks
Re: shorting points
the image is not clear try this
Re: shorting points
Thanks a lot for your answer. It is working now.
François
François
Re: shorting points
Glad to hear that
good luck
good luck
Re: shorting points
hello.
Thank you for the information.
Only for info: shorting points also the same in PCB 100603204.
After using the shorting points I got access via terminal and made "Clear Smart" via terminal
F3 T> /1
F3 1> N1
switch off/on hdd, I got full access to the HDD
F3 T> /1
F3 1> N1
