Hello everybody,
I have a Seagate drive which when connected to PC-3000 does stay in Busy mode. Running "DE" or Utility doesnt work because the Drive is not Ready.
After connecting it to Terminal here is the output.
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Head Mask FFFF - Switch to full int.
Spin Ready
8.01 08-23-04 13:54
(P)PATA Reset
Not Interface Age!
AutoRd Err 43 at 00e32f.00.0000
INVALID Cert Disk Code - ROM Resident Revision Required: 8.01
Command Inactive - No VALID Cert Code Detected
T>
After command " ' " it returns:
Cmd Cyl Hd Sct Cnt Stbuf Segl Csct Cbuf Actv Ercd Rtry Flags
Sk FFFFF 0F 0FFF 0000 0000 00 0000 0CBD N FE F7FF.FF.80 00
on command "." it returns
Pgm=00 Trk=0E32F(0E32F).0(0).000(000) Zn=0 Err=FE ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
After command ";" it returns:
RD:0200:10
WR:0210:10
AC:022B:01FF
AS:042A:0065
SC:048F:0201
DP:022B:01FF
BA:0227:03
ST:022A:01
logbps:0200
codebps:0200
uP:0FE2:1E
FM:0220:07
AD:0220:0B
RL:0FDD
SL:0F1A
AL:0F03
MZ:0FF6
$Switch to full int.
AM Reacquired
Age=60 Type=20 MxCyl=16358 MxHd=0 MxSct=294 BSz=0000 TCode=0000
After reading the whole manual and many of the forum post I could still not come to any conclusion on what is wrong.
Could anyone give me a hint or guideline where shall I look or go from here please?
Thank you.
G
Barracuda 7200.7 160GB (Alpine family)
- minimalist
Re: Barracuda 7200.7 160GB (Alpine family)
HDD cannot enter ATA mode. My guess is attempts to switch to ATA mode have damaged some system sectors.
Did you try rewrite CERT information? I see similar errors after "T4E"
Even recovery via Terminal in BSY is not possible without loading CERT.
You have donor of same FW specifications?
- minimalist
AJ2008 wrote:HDD cannot enter ATA mode. My guess is attempts to switch to ATA mode have damaged some system sectors.
Did you try rewrite CERT information? I see similar errors after "T4E"![]()
Hi AJ2008,
I did not try to rewrite CERT. I am at the beginning of diagnosing this drive.
Unfortunatly I have 4 drives like this but they all have different fimrware.
I checked them on the label and in terminal also.
Could you also thell me how and from where I could learn identifying what the terminal gives back to me. There are examples in the manual but I guess that is just the surface.
Thanks,
G
There is no definitive manual as such, and responses can vary between families.
The only way to learn is through experience. Over time you will identify consistent messages with specific failures.
Analyzing the terminal output is a great tool for diagnosis, but understanding it is not easy. There are many replies that I still do not understand, I am still learning myself!
