Hello all.. i have SAMSUNG HM160HC.
Spin up and then Spin down, when i try to recalibrate recalibrate and spin up, and show ready status, this is the terminal error code
HErr! 2004
HErr! 2004
IS=+00000
SO
Ld
ENG>SRV>
SvoTbl Loaded
BD
STW TYPE = 0000
LED 5B
LED 5B
Any Clue?
SAMSUNG HM160HC.
Moderator: Garry_TS
Re: SAMSUNG HM160HC.
LED 5B = Damaged FW Modules
Make hotswap, check for errors in ALIST or in SMART.
Thanks.. i will do it, thank you all.
[quote="AJ2008"]Make hotswap, check for errors in ALIST or in SMART.[/quote
Alist Bad Smart ok ( some others module is bad ) what I can do !?!?!?!
Heads number and Selected value are in RED colour
Family selected: M5_P1 2.5''
Model................................... : HM160HC
Technological ID
Flash version........................... :
Heads number............................ : 0
Selected value.......................... : 1
SA SPT.................................. : 960
Modules table loaded from SA
Service Area
Head map................................ : 1, 0
Part Number............................. : C6951A221AB2D9
Module header of BISPT.................. : END
SA structure test
Modules checking
00 FSI.................................. : Head: 0, Ok
02 FIT.................................. : Head: 0, Ok
06 MLIST................................ : Head: 0, Ok
07 SRVTBL............................... : Head: 0, Ok
53 SEEKTIME............................. : Head: 0, Read sector error (c: 0,h:0,s: 11); Device Error Detected 51/01 (AMN)
8E...................................... : Head: 0, Read sector error (c: 1,h:0,s: 211); Device Error Detected 51/40 (UNC)
5D SNBACKUP............................. : Head: 0, Ok
5F LMBACKUP............................. : Head: 0, Ok
61 REF_TMR.............................. : Head: 0, Read sector error (c: 0,h:0,s: 27); Device Error Detected 51/01 (AMN)
4C SPSTW_DA............................. : Head: 0, Ok
98 FAILCODE............................. : Head: 0, Read sector error (c: 0,h:0,s: 19); Device Error Detected 51/01 (AMN)
5B MODEL_ID............................. : Head: 0, Ok
5E CHN_TBL2............................. : Head: 0, Ok
77 PROC_CNT............................. : Head: 0, Ok
75 STR_RSRT............................. : Head: 0, Ok
04 CONFIG............................... : Head: 0, Ok
05 SNTBL................................ : Head: 0, Ok
08 BISPT................................ : Head: 0, Ok
09 BRSLT................................ : Head: 0, Ok
7B CRITERIA............................. : Head: 0, Hdr error
0B FINALTST............................. : Head: 0, Ok
0A ARCOTBL.............................. : Head: 0, Ok
7A GEO_TBL.............................. : Head: 0, Ok
0C VLISTHDR............................. : Head: 0, Ok
0D VLIST................................ : Head: 0, Ok
55 FDT_TBL.............................. : Head: 0, Ok
54 RDRTY_01............................. : Head: 0, Ok
0E SLISTHDR............................. : Head: 0, Ok
0F SLIST................................ : Head: 0, Read sector error (c: 6,h:0,s: 256); Device Error Detected 51/10 (INF)
11 ALIST................................ : Head: 0, Read sector error (c: 1,h:0,s: 211); Device Error Detected 51/40 (UNC)
81 RLIST................................ : Head: 0, Ok
64 ALISTHDR............................. : Head: 0, Hdr error
82 RLIST_H.............................. : Head: 0, Hdr error
15 SRVTBL2.............................. : Head: 0, Hdr error
12 TMPRTR............................... : Head: 0, Hdr error
17 OVERLAY.............................. : Head: 0, Read sector error (c: 1,h:0,s: 467); Device Error Detected 51/40 (UNC)
10 TLIST................................ : Head: 0, Hdr error
16 ARCOTBL2............................. : Head: 0, Hdr error
51 M30CODE.............................. : Head: 0, Read sector error (c: 2,h:0,s: 256); Device Error Detected 51/10 (INF)
68 DLIST_H.............................. : Head: 0, Ok
26 DLISTOR.............................. : Head: 0, Read sector error (c: 3,h:0,s: 512); Device Error Detected 51/10 (INF)
95 DLISTOR2............................. : Head: 0, Read sector error (c:24,h:0,s: 512); Device Error Detected 51/10 (INF)
18 HDAF_RPT............................. : Head: 0, Ok
19 HD_DLIST............................. : Head: 0, Ok
1A LUL.................................. : Head: 0, Ok
1B RCOSCRPT............................. : Head: 0, Ok
1D ERRTRK............................... : Head: 0, Ok
1E ERRZN................................ : Head: 0, Hdr error
1F ERRDRV............................... : Head: 0, Ok
20 ER_CNT............................... : Head: 0, Ok
21 SV_ERCNT............................. : Head: 0, Ok
22 PAR_MON.............................. : Head: 0, Ok
23 WKHEAD............................... : Head: 0, Hdr error
25 MRTUNEMT............................. : Head: 0, Ok
1C BTIME................................ : Head: 0, Ok
24 TPI_WRW.............................. : Head: 0, Hdr error
62 HD_BER............................... : Head: 0, Hdr error
4E MRRTABLE............................. : Head: 0, Ok
6D OWC_CSM.............................. : Head: 0, Ok
6C WC_CSM............................... : Head: 0, Ok
6E OSC_OPT.............................. : Head: 0, Ok
28 ERR_HDR.............................. : Head: 0, Ok
29 SMRT_HDR............................. : Head: 0, Ok
2A BISP_HDR............................. : Head: 0, Ok
2B SERIAL_H............................. : Head: 0, Ok
2C PES_HDR.............................. : Head: 0, Ok
2D SVTRC_HD............................. : Head: 0, Ok
42 CAPSEL............................... : Head: 0, Hdr error
44 AZLCSM............................... : Head: 0, Hdr error
5C PWR_CNT.............................. : Head: 0, Ok
56 SPN_MNTR............................. : Head: 0, Hdr error
57 IRD_DOWN............................. : Head: 0, Hdr error
31 ATW_TEST............................. : Head: 0, Hdr error
58 ATW_TST2............................. : Head: 0, Hdr error
38 SPESB0............................... : Head: 0, Hdr error
39 SPESB1............................... : Head: 0, Hdr error
3A SPESB2............................... : Head: 0, Hdr error
3B SPESB3............................... : Head: 0, Hdr error
3C SPESB4............................... : Head: 0, Hdr error
72 WII_SCR2............................. : Head: 0, Ok
73 LOW_BER.............................. : Head: 0, Hdr error
74 WII_BER.............................. : Head: 0, Ok
27 GEO_00............................... : Head: 0, Read sector error (c: 7,h:0,s: 256); Device Error Detected 51/10 (INF)
90 TNU_LOG.............................. : Head: 0, Hdr error
91 LONGSEEK............................. : Head: 0, Hdr error
94 ID_SBER.............................. : Head: 0, Ok
32 SMART................................ : Head: 0, Ok
33 SMRT_LOG............................. : Head: 0, Ok
83 SDATAMEM............................. : Head: 0, Ok
3D ELOG................................. : Head: 0, Read sector error (c:12,h:0,s: 256); Device Error Detected 51/10 (INF)
36 SV_TRACE............................. : Head: 0, Ok
37 PES_LOG.............................. : Head: 0, Ok
40 IPC_DBG.............................. : Head: 0, Ok
69 DLIST................................ : Head: 0, Read sector error (c:21,h:0,s: 256); Device Error Detected 51/10 (INF)
7C FOD_FH............................... : Head: 0, Ok
7E FOD_DATA............................. : Head: 0, Ok
87 FOD_FREQ............................. : Head: 0, Ok
7D FOD_VU............................... : Head: 0, Hdr error
7F FOD_FHT.............................. : Head: 0, Ok
86 FOD_RST.............................. : Head: 0, Ok
9A FOD_RSTH............................. : Head: 0, Ok
99 SBER................................. : Head: 0, Ok
Password information.................... : Loaded
S-LIST.................................. : Read sector error (c: 6,h:0,s: 256); Device Error Detected 51/10 (INF)
T-LIST.................................. : Module header error
A-LIST.................................. : Read sector error (c: 1,h:0,s: 211); Device Error Detected 51/40 (UNC)
D-LIST.................................. : Read sector error (c:21,h:0,s: 256); Device Error Detected 51/10 (INF)
Test completed
Soft reset ...
Modules checking
00 FSI.................................. : Ok
02 FIT.................................. : Ok
06 MLIST................................ : Ok
07 SRVTBL............................... : Ok
53 SEEKTIME............................. : Read sector error (c: 0,h:0,s: 11); Device Error Detected 51/01 (AMN)
8E...................................... : Read sector error (c: 1,h:0,s: 211); Device Error Detected 51/40 (UNC)
5D SNBACKUP............................. : Ok
5F LMBACKUP............................. : Ok
61 REF_TMR.............................. : Read sector error (c: 0,h:0,s: 27); Device Error Detected 51/01 (AMN)
4C SPSTW_DA............................. : Ok
98 FAILCODE............................. : Read sector error (c: 0,h:0,s: 19); Device Error Detected 51/01 (AMN)
5B MODEL_ID............................. : Ok
5E CHN_TBL2............................. : Ok
77 PROC_CNT............................. : Ok
75 STR_RSRT............................. : Ok
04 CONFIG............................... : Ok
05 SNTBL................................ : Ok
08 BISPT................................ : Ok
09 BRSLT................................ : Ok
7B CRITERIA............................. : Ok
0B FINALTST............................. : Ok
0A ARCOTBL.............................. : Ok
7A GEO_TBL.............................. : Ok
0C VLISTHDR............................. : Ok
0D VLIST................................ : Ok
55 FDT_TBL.............................. : Ok
54 RDRTY_01............................. : Ok
0E SLISTHDR............................. : Ok
0F SLIST................................ : Read sector error (c: 6,h:0,s: 256); Device Error Detected 51/10 (INF)
11 ALIST................................ : Read sector error (c: 1,h:0,s: 211); Device Error Detected 51/40 (UNC)
81 RLIST................................ : Ok
64 ALISTHDR............................. : Ok
82 RLIST_H.............................. : Ok
15 SRVTBL2.............................. : Ok
12 TMPRTR............................... : Ok
17 OVERLAY.............................. : Read sector error (c: 1,h:0,s: 467); Device Error Detected 51/40 (UNC)
10 TLIST................................ : Ok
16 ARCOTBL2............................. : Ok
51 M30CODE.............................. : Read sector error (c: 2,h:0,s: 256); Device Error Detected 51/10 (INF)
68 DLIST_H.............................. : Ok
26 DLISTOR.............................. : Read sector error (c: 3,h:0,s: 512); Device Error Detected 51/10 (INF)
95 DLISTOR2............................. : Read sector error (c:24,h:0,s: 512); Device Error Detected 51/10 (INF)
18 HDAF_RPT............................. : Ok
19 HD_DLIST............................. : Ok
1A LUL.................................. : Ok
1B RCOSCRPT............................. : Ok
1D ERRTRK............................... : Ok
1E ERRZN................................ : Ok
1F ERRDRV............................... : Ok
20 ER_CNT............................... : Ok
21 SV_ERCNT............................. : Ok
22 PAR_MON.............................. : Ok
23 WKHEAD............................... : Ok
25 MRTUNEMT............................. : Ok
1C BTIME................................ : Ok
24 TPI_WRW.............................. : Ok
62 HD_BER............................... : Ok
4E MRRTABLE............................. : Ok
6D OWC_CSM.............................. : Ok
6C WC_CSM............................... : Ok
6E OSC_OPT.............................. : Ok
28 ERR_HDR.............................. : Ok
29 SMRT_HDR............................. : Ok
2A BISP_HDR............................. : Ok
2B SERIAL_H............................. : Ok
2C PES_HDR.............................. : Ok
2D SVTRC_HD............................. : Ok
42 CAPSEL............................... : Ok
44 AZLCSM............................... : Ok
5C PWR_CNT.............................. : Ok
56 SPN_MNTR............................. : Ok
57 IRD_DOWN............................. : Ok
31 ATW_TEST............................. : Ok
58 ATW_TST2............................. : Ok
38 SPESB0............................... : Ok
39 SPESB1............................... : Ok
3A SPESB2............................... : Ok
3B SPESB3............................... : Ok
3C SPESB4............................... : Ok
72 WII_SCR2............................. : Ok
73 LOW_BER.............................. : Ok
74 WII_BER.............................. : Ok
27 GEO_00............................... : Read sector error (c: 7,h:0,s: 256); Device Error Detected 51/10 (INF)
90 TNU_LOG.............................. : Ok
91 LONGSEEK............................. : Ok
94 ID_SBER.............................. : Ok
32 SMART................................ : Ok
33 SMRT_LOG............................. : Ok
83 SDATAMEM............................. : Ok
3D ELOG................................. : Read sector error (c:12,h:0,s: 256); Device Error Detected 51/10 (INF)
36 SV_TRACE............................. : Ok
37 PES_LOG.............................. : Ok
40 IPC_DBG.............................. : Ok
69 DLIST................................ : Read sector error (c:21,h:0,s: 256); Device Error Detected 51/10 (INF)
7C FOD_FH............................... : Ok
7E FOD_DATA............................. : Ok
87 FOD_FREQ............................. : Ok
7D FOD_VU............................... : Ok
7F FOD_FHT.............................. : Ok
86 FOD_RST.............................. : Ok
9A FOD_RSTH............................. : Ok
99 SBER................................. : Ok
Test completed
Module 11 ALIST checking
Test completed
Thank you
Technological ID
Service Area
SA structure test
Modules checking
Test completed
Soft reset ...
Modules checking
Test completed
Test completed
Thank you
Hi AJ2008,
Do you know which module must be tansfered from patient to donor of HM160HC (M5_P1) family
thanx
thanx
As far as I know it should be all modules except overlays, but it may be worth getting someone from Ace support to confirm if it is he same for this model.
Here you have several modules that are damaged that are specific, such as SLIST and Overlay module.
this model has 2 heads so it has 2 SA copies, can you read SA in composite or can you read copy 1 with less errors?
