How to know the used space of hard drive
aribot
Postby aribot » 13.12.11, 10:18
Hope is an easy question.
Is possible to know the used space of the whole partition when you are in Explorer mode? Or may be posible to know the size of a folder and all its contents?
Thanks.
Smith
Re: How to know the used space of hard drive
Postby Smith » 15.12.11, 10:33
If you mark the data and generate map then it tells you the size of marked items. Hope this is what you needed.
Postby AJ2008 » 09.05.12, 11:02
Select "Used Sectors from $Bitmap" option...
Return to “Data Extractor”
