after changing the heads to the Seagate ST31000528AS disk remains BSY.
I tried to run the utility to resolve the problem but did not give any results
Has anyone had the same problem?
changing heads on Seagate ST31000528AS disk remains bsy
Re: changing heads on Seagate ST31000528AS disk remains bsy
For Seagate drives you can check the situation by viewing the terminal ouput.
Also, if you will not see anything in terminal , tell me, have you checked the logic board on it?
More details are required.
Hello Roustam
the terminal output is:
Rst 0x20M
Servo Processor Is Reset.
ExecuteSpinRequest
No HOST FIS-ReadyStatusFlags 2002B001
Rst 0x20M
ExecuteSpinRequest
This is bad translator. Try to read SA modules, is there problem with 002b.rpm ?
BSY on the disc is left from when I tried to regenerate the translator.
The regeneration is not successful, and now I can not do any operation on your hard drive.
Should I first get out of BSY
Hi, i have same drive and got same problem, right now the drive keep in BSY. i unscrew the PCB and HDA, just connect PCB it can't get ready, so the question is how can i let drive come back to ready?
Thanks for any suggestion.
Specific revisions do not allow ATA mode with PCB alone. Some cases may require short circuit.
