WD3200AAJS-65B4A0 not recognized
rcz
Postby rcz » 13.03.12, 18:49
This disk isn't recognized.
As you can see, I don't know why, there isn't any module 11...
I change heads, same problem.
Do you have an idea ?
Techno mode key
RAM:
Cyl Count............................... : 170
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM version............................. : 05.65A
ROM generation.......................... : 05.65A
Link table version...................... : 04.2K.
Consolidated ROM version................ : 00050065
ROM Modules:
Modules directory address............... : FIXED
ROM Firmware version.................... : 00050065
Service area:
SA dir reading (ID)..................... : FM ERR NO SD CREATED FOR THE REQUESTED FILE ID
SA dir reading (ABA/CHS)................ : Ok
SA Access............................... : Copy 1
SA structure test
Module 0001 Copy 1...................... : Ok
Module 0035 Copy 1...................... : Ok
Module 00C1 Copy 1...................... : Ok
Module 0100 Copy 1...................... : Ok
Module 0108 Copy 1...................... : Ok
Module 0109 Copy 1...................... : Ok
Module 0033 Copy 1...................... : Ok
Module 0031 Copy 1...................... : Ok
Module 000C Copy 1...................... : Ok
Module 0034 Copy 1...................... : Ok
Module 0032 Copy 1...................... : Ok
Module 0036 Copy 1...................... : Ok
Module 0029 Copy 1...................... : Ok
Module 0040 Copy 1...................... : Ok
Module 0041 Copy 1...................... : Ok
Module 0042 Copy 1...................... : Ok
Module 0043 Copy 1...................... : Ok
Module 004E Copy 1...................... : Ok
Module 0049 Copy 1...................... : Ok
Module 004A Copy 1...................... : Ok
Module 004D Copy 1...................... : Ok
Module 0003 Copy 1...................... : Ok
Module 0004 Copy 1...................... : Ok
Module 0025 Copy 1...................... : Ok
Module 0026 Copy 1...................... : Ok
Module 0038 Copy 1...................... : Ok
Module 0039 Copy 1...................... : Ok
Module 0037 Copy 1...................... : Ok
Module 002D Copy 1...................... : Ok
Module 0068 Copy 1...................... : Ok
Module 0069 Copy 1...................... : Ok
Module 006A Copy 1...................... : Ok
Module 00B5 Copy 1...................... : Ok
Module 006B Copy 1...................... : Ok
Module 003A Copy 1...................... : Ok
Module 0028 Copy 1...................... : Ok
Module 003B Copy 1...................... : Ok
Module 003C Copy 1...................... : Ok
Module 003D Copy 1...................... : Ok
Module 003E Copy 1...................... : Ok
Module 003F Copy 1...................... : Ok
Module 006D Copy 1...................... : Ok
Module 0119 Copy 1...................... : Ok
Module 0101 Copy 1...................... : Ok
Module 00A8 Copy 1...................... : Ok
Module 00A2 Copy 1...................... : Ok
Module 00C5 Copy 1...................... : Ok
Module 00C3 Copy 1...................... : Ok
Module 00C8 Copy 1...................... : Ok
Module 0091 Copy 1...................... : Ok
Module 00C2 Copy 1...................... : Ok
Module 00A1 Copy 1...................... : Ok
Module 0099 Copy 1...................... : Ok
Module 0098 Copy 1...................... : Ok
Module 00CD Copy 1...................... : Ok
Module 00CF Copy 1...................... : Ok
Module 00CE Copy 1...................... : Ok
Module 0093 Copy 1...................... : Ok
Module 00C6 Copy 1...................... : Ok
Module 00C9 Copy 1...................... : Ok
Module 0094 Copy 1...................... : Ok
Module 0096 Copy 1...................... : Ok
Module 0097 Copy 1...................... : Ok
Module 00A5 Copy 1...................... : Ok
Module 00A6 Copy 1...................... : Ok
Module 0092 Copy 1...................... : Ok
Module 00A0 Copy 1...................... : Ok
Module 009A Copy 1...................... : Ok
Module 2000 Copy 1...................... : Ok
Module 2001 Copy 1...................... : Ok
Module 2002 Copy 1...................... : Ok
Module 2003 Copy 1...................... : Ok
Module 2004 Copy 1...................... : Ok
Module 2005 Copy 1...................... : Ok
Module 2006 Copy 1...................... : Ok
Module 2007 Copy 1...................... : Ok
Module 2020 Copy 1...................... : Ok
Module 2021 Copy 1...................... : Ok
Module 2022 Copy 1...................... : Ok
Module 2023 Copy 1...................... : Ok
Module 2024 Copy 1...................... : Ok
Module 2025 Copy 1...................... : Ok
Module 2026 Copy 1...................... : Ok
Module 2027 Copy 1...................... : Ok
Module 2030 Copy 1...................... : Ok
Module 2031 Copy 1...................... : Ok
Module 2032 Copy 1...................... : Ok
Module 2033 Copy 1...................... : Ok
Module 2034 Copy 1...................... : Ok
Module 2035 Copy 1...................... : Ok
Module 2036 Copy 1...................... : Ok
Module 2037 Copy 1...................... : Ok
Module 2010 Copy 1...................... : Ok
Module 2011 Copy 1...................... : Ok
Module 2012 Copy 1...................... : Ok
Module 2013 Copy 1...................... : Ok
Module 2014 Copy 1...................... : Ok
Module 2015 Copy 1...................... : Ok
Module 2016 Copy 1...................... : Ok
Module 2017 Copy 1...................... : Ok
Module 2040 Copy 1...................... : Ok
Module 2041 Copy 1...................... : Ok
Module 2042 Copy 1...................... : Ok
Module 2043 Copy 1...................... : Ok
Module 2044 Copy 1...................... : Ok
Module 2045 Copy 1...................... : Ok
Module 2046 Copy 1...................... : Ok
Module 2047 Copy 1...................... : Ok
Module 2050 Copy 1...................... : Ok
Module 2051 Copy 1...................... : Ok
Module 2052 Copy 1...................... : Ok
Module 2053 Copy 1...................... : Ok
Module 2054 Copy 1...................... : Ok
Module 2055 Copy 1...................... : Ok
Module 2056 Copy 1...................... : Ok
Module 2057 Copy 1...................... : Ok
Module 2060 Copy 1...................... : Ok
Module 2061 Copy 1...................... : Ok
Module 2062 Copy 1...................... : Ok
Module 2063 Copy 1...................... : Ok
Module 2064 Copy 1...................... : Ok
Module 2065 Copy 1...................... : Ok
Module 2066 Copy 1...................... : Ok
Module 2067 Copy 1...................... : Ok
Module 120F Copy 1...................... : CS & Header
Module 1110 Copy 1...................... : CS & Header
Module 1101 Copy 1...................... : CS & Header
Module 8010 Copy 1...................... : CS & Header
Module 802C Copy 1...................... : CS & Header
Module 8035 Copy 1...................... : CS & Header
Module 8038 Copy 1...................... : Header
Module 803C Copy 1...................... : Header
Module 8016 Copy 1...................... : Header
Module 801D Copy 1...................... : CS & Header
Module 8044 Copy 1...................... : CS & Header
Module 8031 Copy 1...................... : Header
Module 8062 Copy 1...................... : Header
Module 8063 Copy 1...................... : Header
Module 8041 Copy 1...................... : Header
Module 8042 Copy 1...................... : Header
Module 800E Copy 1...................... : Header
Module 802D Copy 1...................... : Header
Module 8019 Copy 1...................... : Header
Module 802F Copy 1...................... : CS & Header
Module 8034 Copy 1...................... : CS & Header
Module 802E Copy 1...................... : Header
Module 8032 Copy 1...................... : CS & Header
Module 8017 Copy 1...................... : CS & Header
Module 8002 Copy 1...................... : CS & Header
Module 800B Copy 1...................... : CS & Header
Module 8005 Copy 1...................... : CS & Header
Module 8020 Copy 1...................... : Header
Module 8046 Copy 1...................... : Header
Module 8045 Copy 1...................... : Header
Module 8027 Copy 1...................... : Header
Module 8014 Copy 1...................... : Header
Module 801C Copy 1...................... : CS & Header
Module 8023 Copy 1...................... : CS & Header
Module 801F Copy 1...................... : Header
Module 803A Copy 1...................... : Header
Module 803E Copy 1...................... : CS & Header
Module 8012 Copy 1...................... : CS & Header
Module 8026 Copy 1...................... : CS & Header
Module 802B Copy 1...................... : Header
Module 8029 Copy 1...................... : Header
Module 802A Copy 1...................... : Header
Module 8037 Copy 1...................... : Header
Module 803B Copy 1...................... : CS & Header
Module 800F Copy 1...................... : CS & Header
Module 800A Copy 1...................... : Header
Module 8025 Copy 1...................... : CS & Header
Module 8009 Copy 1...................... : CS & Header
Module 800C Copy 1...................... : CS & Header
Module 8006 Copy 1...................... : CS & Header
Module 8018 Copy 1...................... : CS & Header
Module 800D Copy 1...................... : CS & Header
Module 8008 Copy 1...................... : Header
Module 8024 Copy 1...................... : CS & Header
Module 8015 Copy 1...................... : CS & Header
Module 8007 Copy 1...................... : CS & Header
Module 8065 Copy 1...................... : Header
Module 801A Copy 1...................... : CS & Header
Module 8030 Copy 1...................... : CS & Header
Module 801E Copy 1...................... : CS & Header
Module 8001 Copy 1...................... : Header
Module 8022 Copy 1...................... : Header
Module 8064 Copy 1...................... : Header
Module 8049 Copy 1...................... : Header
Module 805D Copy 1...................... : Header
Module 805E Copy 1...................... : Header
Module 805F Copy 1...................... : Header
Module 8060 Copy 1...................... : Header
Module 8061 Copy 1...................... : Header
Module 8011 Copy 1...................... : Header
Module 803F Copy 1...................... : Header
Module 8040 Copy 1...................... : Header
Module 8033 Copy 1...................... : CS & Header
Module 8043 Copy 1...................... : CS & Header
Module 8000 Copy 1...................... : CS & Header
Module 8021 Copy 1...................... : CS & Header
Module 8FFC Copy 1...................... : Header
Module 8FFD Copy 1...................... : Header
Module 8FFE Copy 1...................... : Header
Module 8047 Copy 1...................... : CS & Header
Module 8048 Copy 1...................... : CS & Header
Module 8004 Copy 1...................... : CS & Header
Module 8003 Copy 1...................... : CS & Header
Module 8028 Copy 1...................... : CS & Header
Module 8039 Copy 1...................... : Header
Module 803D Copy 1...................... : Header
Module 8036 Copy 1...................... : Header
Module 801B Copy 1...................... : Header
Module 8013 Copy 1...................... : Header
Module 804C Copy 1...................... : Header
Module 804D Copy 1...................... : Header
Module 804E Copy 1...................... : Header
Module 804F Copy 1...................... : Header
Module 804A Copy 1...................... : Header
Module 804B Copy 1...................... : Header
Module 8050 Copy 1...................... : Header
Module 8051 Copy 1...................... : Header
Module 8052 Copy 1...................... : Header
Module 8053 Copy 1...................... : Header
Module 8054 Copy 1...................... : Header
Module 8055 Copy 1...................... : Header
Module 8056 Copy 1...................... : Header
Module 8057 Copy 1...................... : Header
Module 8058 Copy 1...................... : Header
Module 8059 Copy 1...................... : Header
Module 805A Copy 1...................... : Header
Module 805B Copy 1...................... : Header
Module 805C Copy 1...................... : Header
Module 8066 Copy 1...................... : Header
Module 8067 Copy 1...................... : Header
Module 8068 Copy 1...................... : CS & Header
Module 8069 Copy 1...................... : CS & Header
Module 00C4 Copy 1...................... : Ok
Module 00FE Copy 1...................... : Ok
Module 00FB Copy 1...................... : CS & Header
Module 00E8 Copy 1...................... : CS & Header
Module 00E1 Copy 1...................... : Ok
Module 00E0 Copy 1...................... : Ok
Module 00C7 Copy 1...................... : Header
Module 00DE Copy 1...................... : CS & Header
Module 00B6 Copy 1...................... : Ok
Module 00D5 Copy 1...................... : CS & Header
Module 00D1 Copy 1...................... : CS & Header
Module 00DA Copy 1...................... : CS & Header
Module 00DB Copy 1...................... : CS & Header
Module 00DF Copy 1...................... : CS & Header
Module 00DD Copy 1...................... : CS & Header
Module 00D6 Copy 1...................... : Ok
Module 00D7 Copy 1...................... : CS & Header
Module 00D2 Copy 1...................... : CS & Header
Module 3300 Copy 1...................... : CS & Header
Module 3301 Copy 1...................... : CS & Header
Module 00BB Copy 1...................... : CS & Header
Module 3405 Copy 1...................... : CS & Header
Module 00D9 Copy 1...................... : CS & Header
Module 00D4 Copy 1...................... : CS & Header
Module 00DC Copy 1...................... : Ok
Module 00D0 Copy 1...................... : CS & Header
Module 00D3 Copy 1...................... : CS & Header
Module 00BA Copy 1...................... : CS & Header
Module 00B9 Copy 1...................... : CS & Header
Module 00BC Copy 1...................... : CS & Header
Module 00BD Copy 1...................... : CS
Module 00BE Copy 1...................... : CS & Header
Module 3400 Copy 1...................... : CS & Header
Module 3401 Copy 1...................... : Ok
Module 00B8 Copy 1...................... : Header
Module 00BF Copy 1...................... : Header
Module 00E6 Copy 1...................... : Ok
Module 00E7 Copy 1...................... : Header
Module 3801 Copy 1...................... : CS & Header
Module 0106 Copy 1...................... : Ok
Module 0107 Copy 1...................... : Ok
Module 0105 Copy 1...................... : Ok
Module 0104 Copy 1...................... : Ok
Module 0103 Copy 1...................... : Ok
Module 0102 Copy 1...................... : Ok
Module 0110 Copy 1...................... : Ok
Module 00CC Copy 1...................... : Ok
Module 009E Copy 1...................... : Ok
Module 0002 Copy 1...................... : Ok
Module 0017 Copy 1...................... : Ok
Module 001B Copy 1...................... : Ok
Module 001C Copy 1...................... : Ok
Module 0014 Copy 1...................... : Ok
Module 0015 Copy 1...................... : Ok
Module 001E Copy 1...................... : Ok
Module 002F Copy 1...................... : Ok
Module 002A Copy 1...................... : Ok
Module 0021 Copy 1...................... : Ok
Module 0022 Copy 1...................... : Ok
Module 0023 Copy 1...................... : Ok
Module 0024 Copy 1...................... : Ok
Module 0013 Copy 1...................... : Ok
Module 0080 Copy 1...................... : Ok
Module 0019 Copy 1...................... : Ok
Module 0012 Copy 1...................... : Ok
Module 0050 Copy 1...................... : Ok
Module 0051 Copy 1...................... : Ok
Module 0052 Copy 1...................... : Ok
Module 0053 Copy 1...................... : Ok
Module 00CA Copy 1...................... : Ok
Module 00CB Copy 1...................... : Ok
Module 009C Copy 1...................... : Ok
Module 3E00 Copy 1...................... : Ok
Module 00EE Copy 1...................... : Ok
Module 00FD Copy 1...................... : Ok
Module 00FC Copy 1...................... : Ok
Module 00FA Copy 1...................... : Ok
Module 00B7 Copy 1...................... : Ok
Module 0061 Copy 1...................... : Ok
Module 0062 Copy 1...................... : Ok
Module 001F Copy 1...................... : Ok
Module 006E Copy 1...................... : Ok
Module 4002 Copy 1...................... : Ok
Re: WD3200AAJS-65B4A0 not recognized
Postby ACE_Admin » 16.03.12, 09:27
hello
WD3200AAJS-65B4A0 - is a pinnacle family.
Try reading the following modules and see if they are not rewritten or damaged completely. Compare the data from each module with one from similar model drive's modules in Database. If all Ad As modules are good, then I advise you to fix their CS with plugin and save your changes.
It can happen, the drive will report error after you will try to rewrite modules. In this situation you can try to change module location by dir editing or get a donor drive and make a hot-swap according to the rules for WD Marvell drives.
rcz
Postby rcz » 20.03.12, 09:36
Modules "Ad" and "As" are good (green).
I tried to write damaged "B" modules from donor (by ABA, I can't write by ID). Some became good, some became with CS error or header, module is not written properly.
If I correct CS or header, module still won't be good ?
Igor
Postby Igor » 21.03.12, 16:13
I suppose that you performed modules searching in SA and then saved DIR to disk. This function sometimes does not work good.
11 module was not found during modules searching, and that is why you do not see it now.
Now very important question:
do you have initial backup of the DIR module? If so rewrite it by ABA, run utility in normal mode and post here the log from utility.
rcz
Postby rcz » 21.03.12, 16:27
Hi Igor,
I haven't done this. Drive is not recognized, I put it in Normal mode and search SA SPT. I can read modules like this (maybe taht's not a good method). That's all I've done and I have initial back up.
I have to point that customer has just give up the recovery right now. Solution is now very less important.
Igor
Postby Igor » 22.03.12, 12:45
Well, in this case I can suppose that someone before "worked" with this drive.
In other case (if no one played with drive before) DIR module has very exotic damage.
rcz
Postby rcz » 22.03.12, 13:39
There is no "trace" of previous work on this drive (like a label of another recovery company) but we are never sure of it.
I wondered how module 11 could have disappeared too...
Thank you Igor ;)
Igor
Postby Igor » 22.03.12, 15:43
I suppose that initially this drive had some problems with 11 module, then someone ran modules searching in SA. This function reads SA tracks and then searched by raw recovery headers of the modules. After that utility checks control sum and if everything is ok, utility shows that module is found.
So if some module has some problems (damaged headers, or wrong CS) it will not be found.
To prevent your question "why next modules are shown:"
and so on...
again I can suppose that now SA is not readable till one certain point, and after this point all modules are damaged.
Why it happens? SA has translator like user area. If we lose one bad sector from translator, we will see situation like with Seagate F3 drives that appears sometimes (you can read user data till one certain point).
So, the full story is
someone ran modules searching in SA, then saved virtual DIR to the SA, then rewrote ROM (and lost original SA translator) and after all these tricks we see such situation :)
Something like this....
rcz
Postby rcz » 30.04.12, 17:43
Hi Igor,
I have an other PINNACLE (PATA) with a similar problem (WD1600AAJB-00J3A0)
HDD seems to initialize, DRD-DSC but no ID (it doesn't spin down), Utility can find SA SPT, and I can search module. I can find Dir but still no Module 11. Again I see that modules are good until an adress, then they all broken.
This drive has one physical head only.
Do you know what should I do ? I have no similar drive now, I ordered one WD1600AAJB-00J3A0 but customer is hurried if you have an idea...
Igor
Postby Igor » 02.05.12, 14:42
Paste here utility start log in normal mode with and without loader.
rcz
Postby rcz » 03.05.12, 10:45
I haven't any loader.
At first launch SA SPT is requested :
SA SPT.JPG (24.35 KiB) Viewed 15190 times
Then I have this :
Techno mode key
RAM:
ROM:
ROM version............................. : 02.C0E
ROM generation.......................... : 02.C0E
Link table version...................... : 03.09.
Consolidated ROM version................ : 000200C0
ROM Modules:
Heads number in use..................... : 1
ROM Firmware version.................... : 000200C0
Service area:
Configuration reading................... : No SA copy avalabled
Igor
Postby Igor » 03.05.12, 10:48
Now run reading SA modules by ID and paste the log.
rcz
Postby rcz » 03.05.12, 11:20
Modules checking
Module 01............................... : Ok
Module 35............................... : Ok
Module 6D............................... : Ok
Module 110.............................. : Ok
Module 102.............................. : Ok
Module 103.............................. : Ok
Module 104.............................. : Ok
Module 105.............................. : Ok
Module 107.............................. : Ok
Module 106.............................. : Ok
Module 108.............................. : Ok
Module 02............................... : Ok
Module 17............................... : Ok
Module 1B............................... : Ok
Module 1C............................... : Ok
Module 14............................... : Ok
Module 15............................... : Ok
Module 1E............................... : Ok
Module 2F............................... : Ok
Module 2A............................... : Ok
Module 21............................... : Ok
Module 22............................... : Ok
Module 23............................... : Error
Module 24............................... : Error
Module 13............................... : Ok
Module 80............................... : Ok
Module 11............................... : Ok
Module 19............................... : Ok
Module 12............................... : Ok
Module 50............................... : Ok
Module 51............................... : Ok
Module 52............................... : Ok
Module 53............................... : Ok
Module 109.............................. : Ok
Module 61............................... : Ok
Module 62............................... : Ok
Module 1F............................... : Ok
Module 6E............................... : Ok
Module 6F............................... : Ok
Module 116.............................. : Ok
Module 118.............................. : Ok
Module AC55............................. : Ok
Module 4002............................. : Ok
Module 121.............................. : Ok
Module 3604............................. : Ok
Module 33............................... : Ok
Module 31............................... : Ok
Module 0C............................... : Ok
Module 34............................... : Ok
Module 32............................... : Ok
Module 36............................... : Ok
Module 29............................... : Ok
Module 40............................... : Ok
Module 41............................... : Ok
Module 42............................... : Ok
Module 43............................... : Ok
Module 4E............................... : Ok
Module 49............................... : Ok
Module 4A............................... : Ok
Module 4D............................... : Ok
Module 03............................... : Ok
Module 04............................... : Ok
Module 25............................... : Ok
Module 26............................... : Ok
Module 38............................... : Ok
Module 39............................... : Ok
Module 37............................... : Ok
Module 2D............................... : Ok
Module 2E............................... : Ok
Module 68............................... : Ok
Module 69............................... : Ok
Module 6A............................... : Ok
Module B5............................... : Ok
Module 6B............................... : Ok
Module 3A............................... : Ok
Module 28............................... : Ok
Module 3B............................... : Ok
Module 3C............................... : Ok
Module 3D............................... : Ok
Module 3E............................... : Ok
Module 3F............................... : Ok
Module 119.............................. : Ok
Module 115.............................. : Ok
Module DE............................... : Ok
Module B6............................... : Ok
Module D5............................... : Ok
Module 3411............................. : Ok
Module D1............................... : Ok
Module DB............................... : Ok
Module DF............................... : Ok
Module DD............................... : Ok
Module D6............................... : Ok
Module 3402............................. : Ok
Module D7............................... : Ok
Module D2............................... : Ok
Module 3300............................. : Ok
Module 3301............................. : Ok
Module 3400............................. : Ok
Module BB............................... : Ok
Module 3405............................. : Ok
Module D9............................... : Ok
Module D4............................... : Ok
Module DC............................... : Ok
Module D0............................... : Ok
Module D3............................... : Ok
Module F7............................... : Ok
Module BA............................... : Ok
Module 3406............................. : Ok
Module B9............................... : Ok
Module BC............................... : Ok
Module D8............................... : Ok
Module BD............................... : Ok
Module BE............................... : Ok
Module 3401............................. : Ok
Module 3302............................. : Ok
Module B8............................... : Ok
Module BF............................... : Ok
Module E6............................... : Ok
Module E7............................... : Ok
Module B7............................... : Ok
Module FA............................... : Ok
Module FC............................... : Ok
Module FD............................... : Ok
Module EE............................... : Ok
Module 3E00............................. : Ok
Module 3801............................. : Ok
Module 3C00............................. : Ok
Module 3415............................. : Ok
Module C4............................... : Ok
Module A8............................... : Ok
Module A2............................... : Ok
Module C5............................... : Ok
Module C3............................... : Ok
Module C8............................... : Ok
Module 91............................... : Ok
Module CC............................... : Ok
Module CA............................... : Ok
Module 99............................... : Ok
Module 98............................... : Ok
Module CB............................... : Ok
Module CD............................... : Ok
Module CF............................... : Ok
Module CE............................... : Ok
Module 93............................... : Ok
Module C1............................... : Ok
Module C2............................... : Ok
Module C7............................... : Ok
Module 9E............................... : Ok
Module C6............................... : Ok
Module C9............................... : Ok
Module 94............................... : Ok
Module 96............................... : Ok
Module 97............................... : Ok
Module AA............................... : Ok
Module A9............................... : Ok
Module A5............................... : Ok
Module A6............................... : Ok
Module 92............................... : Ok
Module A0............................... : Ok
Module A1............................... : Ok
Module 9A............................... : Ok
Module 9C............................... : Ok
Module 2000............................. : Ok
Module 2001............................. : Ok
Module 2002............................. : Ok
Module 2003............................. : Ok
Module 2004............................. : Ok
Module 2005............................. : Ok
Module 2006............................. : Ok
Module 2007............................. : Ok
Module 2020............................. : Ok
Module 2021............................. : Ok
Module 2022............................. : Ok
Module 2023............................. : Ok
Module 2024............................. : Ok
Module 2025............................. : Ok
Module 2026............................. : Ok
Module 2027............................. : Ok
Module 2030............................. : Ok
Module 2031............................. : Ok
Module 2032............................. : Ok
Module 2033............................. : Ok
Module 2034............................. : Ok
Module 2035............................. : Ok
Module 2036............................. : Ok
Module 2037............................. : Ok
Module 2010............................. : Ok
Module 2011............................. : Ok
Module 2012............................. : Ok
Module 2013............................. : Ok
Module 2014............................. : Ok
Module 2015............................. : Ok
Module 2016............................. : Ok
Module 2017............................. : Ok
Module 2040............................. : Ok
Module 2041............................. : Ok
Module 2042............................. : Ok
Module 2043............................. : Ok
Module 2044............................. : Ok
Module 2045............................. : Ok
Module 2046............................. : Ok
Module 2047............................. : Ok
Module 2050............................. : Ok
Module 2051............................. : Ok
Module 2052............................. : Ok
Module 2053............................. : Ok
Module 2054............................. : Ok
Module 2055............................. : Ok
Module 2056............................. : Ok
Module 2057............................. : Ok
Module 2060............................. : Ok
Module 2061............................. : Ok
Module 2062............................. : Ok
Module 2063............................. : Ok
Module 2064............................. : Ok
Module 2065............................. : Ok
Module 2066............................. : Ok
Module 2067............................. : Ok
Module 8010............................. : Ok
Module 802C............................. : Ok
Module 8035............................. : Ok
Module 8038............................. : Ok
Module 803C............................. : Ok
Module 8016............................. : Ok
Module 801D............................. : Ok
Module 8044............................. : Ok
Module 8031............................. : Ok
Module 8062............................. : Ok
Module 8063............................. : Ok
Module 8041............................. : Ok
Module 8042............................. : Ok
Module 800E............................. : Ok
Module 802D............................. : Ok
Module 8019............................. : Ok
Module 802F............................. : Ok
Module 8034............................. : Ok
Module 802E............................. : Ok
Module 8032............................. : Ok
Module 8017............................. : Ok
Module 8002............................. : Ok
Module 800B............................. : Ok
Module 8005............................. : Ok
Module 8020............................. : Ok
Module 8046............................. : Ok
Module 8045............................. : Ok
Module 8027............................. : Ok
Module 8014............................. : Ok
Module 801C............................. : Ok
Module 8023............................. : Ok
Module 801F............................. : Ok
Module 803A............................. : Ok
Module 803E............................. : Ok
Module 8012............................. : Ok
Module 8026............................. : Ok
Module 802B............................. : Ok
Module 8029............................. : Ok
Module 802A............................. : Ok
Module 8037............................. : Ok
Module 803B............................. : Ok
Module 800F............................. : Ok
Module 800A............................. : Ok
Module 8025............................. : Ok
Module 8009............................. : Ok
Module 800C............................. : Ok
Module 8006............................. : Ok
Module 8018............................. : Ok
Module 800D............................. : Ok
Module 8008............................. : Ok
Module 8024............................. : Ok
Module 8015............................. : Ok
Module 8007............................. : Ok
Module 8065............................. : Ok
Module 801A............................. : Ok
Module 8030............................. : Ok
Module 801E............................. : Ok
Module 8001............................. : Ok
Module 8022............................. : Ok
Module 8064............................. : Ok
Module 8049............................. : Ok
Module 805D............................. : Ok
Module 805E............................. : Ok
Module 805F............................. : Ok
Module 8060............................. : Ok
Module 8061............................. : Ok
Module 8011............................. : Ok
Module 803F............................. : Ok
Module 8040............................. : Ok
Module 8033............................. : Ok
Module 8043............................. : Ok
Module 8000............................. : Ok
Module 8021............................. : Ok
Module 8FFC............................. : Ok
Module 8FFD............................. : Ok
Module 8FFE............................. : Ok
Module 8047............................. : Ok
Module 8048............................. : Ok
Module 8004............................. : Ok
Module 8003............................. : Ok
Module 8028............................. : Ok
Module 8039............................. : Ok
Module 803D............................. : Ok
Module 8036............................. : Ok
Module 801B............................. : Ok
Module 8013............................. : Ok
Module 804C............................. : Ok
Module 804D............................. : Ok
Module 804E............................. : Ok
Module 804F............................. : Ok
Module 804A............................. : Ok
Module 804B............................. : Ok
Module 8050............................. : Ok
Module 8051............................. : Ok
Module 8052............................. : Ok
Module 8053............................. : Ok
Module 8054............................. : Ok
Module 8055............................. : Ok
Module 8056............................. : Ok
Module 8057............................. : Ok
Module 8058............................. : Ok
Module 8059............................. : Ok
Module 805A............................. : Ok
Module 805B............................. : Ok
Module 805C............................. : Ok
Module 8066............................. : Ok
Module 8067............................. : Ok
Module 8068............................. : Ok
Module 8069............................. : Ok
Module 806A............................. : Ok
Module 806B............................. : Ok
Module 806C............................. : Ok
Module 1000............................. : Ok
Module B1............................... : Ok
Module B2............................... : Ok
Module 1001............................. : Ok
Module 1002............................. : Ok
Module 1009............................. : Ok
Module 1003............................. : Ok
Module 1005............................. : Ok
Module 1004............................. : Ok
Module 1007............................. : Ok
Module 1008............................. : Ok
Module 1101............................. : Ok
Module 1100............................. : Ok
Module 1110............................. : Ok
Module 1102............................. : Ok
Module E0............................... : Ok
Module FE............................... : Ok
Module FB............................... : Ok
Module 120F............................. : Ok
Module E8............................... : Ok
Module 1213............................. : Ok
I just received the donor I was waiting for. I tried using his loader but isn't compatible.
rcz
Postby rcz » 03.05.12, 18:31
Igor,
I give the case to "Avenger-fr" I won't be present next days.
Please advise us.
avenger-fr
Postby avenger-fr » 07.05.12, 09:42
Hi!
Have you any clues for me this morning ?
