HD322GJ BSY state
Moderator: Garry_TS
BSIT
HD322GJ BSY state
Postby BSIT » 12.01.12, 03:56
Hi all.
I have a spinpoint F4 HD322GJ the spins up clicks once then BSY state.
not spin down, continue spin.
but can't reconize.
it's teminal report after power on.
ActiveFW : 00
FWVer : 0001
DDR size detected = 16MB
SATA PLL cal done
*PA VID=0004 PN=0028 Rev=0003- 885x Found
U
S_0
RV Sensor Circuit Enabled
Shock Sensor Circuit Enabled
SO_1
RPM at Handoff: 3446
Temp : 32 degC
SpinOk
mS1 00000003
SK C:150266 H:0
X24:00000.0.0A7|0549 7A93 L0000000A7 R:3140 00A7 0549/0000
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
Selective MARC NX Loaded
ResoTable Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
| 13 | GEO_TBL | 0 | 0 | 117 | 1140 |
Fw Active 0000
S_3 0000009F 0000009F 00000000 00000001
X13:00001.0.0A7|00EF 0893 LA0000009E R:3140 00A7 00EF/0000
| 115 | MOVLY001 | 1 | 0 | 10 | 1140 |
Overlay file read bad
how can i recover it?
if need hot swap, what modules need fo F4?
dmarques
Re: HD322GJ BSY state
Postby dmarques » 29.02.12, 09:35
Have you tried hotswap to read SA on these one?
