wd10eavs-32d7b1 - wont headmap
drdoc
Postby drdoc » 25.01.12, 03:16
wd10eavs-32d7b1
kermit
clicks 3 times and spins down,
takes a long time to spin down
it wont ram headmap
marvel utility version 4.8.0.3095
techno mode key
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
Cyl Count............................... : 170
ROM version............................. : 05.BME
ROM generation.......................... : 05.BME
Link table version...................... : 04.3D.
Consolidated ROM version................ : 000500BM
ROM Modules:
Heads map............................... : 2,3,4,5,6,7
ROM Firmware version.................... : 000500BM
Family: Kermit
Offset (hex): 4000000
Map Size: 8
RAM Reading: Ok
\x06\x02\x03\x04\x05\x06\x07\x00\x00
\x06\x00\x02\x03\x04\x05\x06\x07\x00\x00
View ROM information
Firmware version........................ : 000500BM
ROM Modules
0A : Heads map
0B : Flash ROM dir
30 : SA Translator
47 : SA Adaptives
0D : Flash configuration
4F : Microprogram version
SA Regions
N : ABA : Size
0 : 0 : 166 950
1 : 225 250 : 166 950
2 : 450 500 : 166 950
3 : 675 750 : 166 950
4 : 901 000 : 166 950
5 : 1 126 250 : 166 950
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 2 : A19/2585
1 : 3 : A09/2569
2 : 4 : A24/2596
3 : 5 : 9BA/2490
4 : 6 : A33/2611
5 : 7 : 9B0/2480
Module 0x90 read error.................. : Module ID 90 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
View module 90 information
Total heads............................. : 6
Used heads.............................. : 6
Mdl 47 version.......................... : DXm0034
ROM Version version..................... : 000500BM (05.BM)
Mdl 11 Version.......................... : 000500BM (05.BM)
hassan
Re: wd10eavs-32d7b1 - wont headmap
Postby hassan » 25.01.12, 09:21
You can try this method
New method of handling WD Caviar HDD Green, Blue and Black
viewtopic.php?f=35&t=7359
