Translator Recovery Problem
datacare
Postby datacare » 12.01.12, 05:59
I have one Seagate 1TB ST31000528AS, Firmware CC46, When i try to recover translator i got the following error,
Start scanning...
"Fork" searching: 0 - 1953525167
Verification error 48-bit (UNC)
PRd: Err Rd Ph Sect 0:0:843(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:843(1)! Tech state 0x72, 0x03110081
LBA : 2115
"Fork" searching: 2116 - 1953525167
Translation "fork" direction detection ambiguity!
Correct it manually!
LBA : 2164
I have manually added the above sectors in defects list, again i got the same problem
Anyone can help in this,
With regards
Sundararajan.P
sicclh
Re: Translator Recovery Problem
Postby sicclh » 16.01.12, 06:15
I have a st3500320ns and st9500325as is like the same problem.
Anyone can help please!
crystalkota
Postby crystalkota » 25.01.12, 13:54
Even I also have the same problem with ST3250318AS with FW CC38....
So anyone may help how to access the data....
Sun
Postby Sun » 21.06.13, 03:42
It can read buy active Utility, but it is very slow, Is anyboby have any suggestion for it?
Postby AJ2008 » 21.06.13, 13:17
Read through utility, it is slow but the best way where forks cant be found properley.
Next time, read V40 before clear translator, then re-import the V40 list to the slip list after translator regenerated.
