WDC WD1600AAJB-00J3A0
erick
Postby erick » 04.01.12, 22:23
Hello. i have this problem whit this hard drive. the drive read ID, make translator regeneration but no data any help.
i ppost the sa thanks to all
Techno mode key
RAM:
Cyl Count............................... : 170
SA SPT.................................. : 1311
ROM:
ROM version............................. : 02.CCE
ROM generation.......................... : 02.CCE
Link table version...................... : 04.0E.
Consolidated ROM version................ : 000200CC
ROM Modules:
Modules directory address............... : FIXED
Heads number in use..................... : 1
Heads map............................... : 0
ROM Firmware version.................... : 000200CC
Service area:
SA dir reading.......................... : Ok
Translator regeneration
Regeneration method..................... : Use P-List only
Completed
dmarques
Re: WDC WD1600AAJB-00J3A0
Postby dmarques » 05.01.12, 14:00
Are you sure all modules are just fine?
What did your client said about it?
erick
Postby erick » 05.01.12, 14:40
Hello all Module looks fine
Id :Copy: Importance: ABA :Size:Read : Hdr : CS : CS Value : Vers. : Desription
0001: 0 : B : 0: 24:Yes : Ok : Ok : 3A1115FE :00020000:Modules directory
0001: 1 : B : 0: 24:Yes : Ok : Ok : 3A1115FE :00020000:Modules directory
0035: 0 : Dd : 24: 10:Yes : Ok : Ok : 4BFE3418 :1013-B34:SA Defects
0035: 1 : Dd : 24: 10:Yes : Ok : Ok : 4BFE3418 :1013-B34:SA Defects
006D: 0 : : 5414: 1:Yes : Ok : Ok : 500D4296 :00010000:
006D: 1 : : 5414: 1:Yes : Ok : Ok : 500D4296 :00010000:
0110: 0 : B :105046: 24:Yes : Ok : Ok : 3CB16E8B :00020000:Modules directory (base part)
0110: 1 : B :105046: 24:Yes : Ok : Ok : 3CB16E8B :00020000:Modules directory (base part)
0102: 0 : Dd :105045: 1:Yes : Ok : Ok : 6BB58629 :00X10002:Heads map module image
0102: 1 : Dd :105045: 1:Yes : Ok : Ok : 6BB58629 :00X10002:Heads map module image
0103: 0 : Dd :105043: 2:Yes : Ok : Ok : 93A75FF5 :FD.0011 :ROM adaptives SA images
0103: 1 : Dd :105043: 2:Yes : Ok : Ok : 93A75FF5 :FD.0011 :ROM adaptives SA images
0104: 0 : Dd :105042: 1:Yes : Ok : Ok : 0CE20B07 :00010000:Microprogram version image
0104: 1 : Dd :105042: 1:Yes : Ok : Ok : 0CE20B07 :00010000:Microprogram version image
0105: 0 : Dd :105040: 2:Yes : Ok : Ok : 4CF43ACF :00160000:ROM translator SA images
0105: 1 : Dd :105040: 2:Yes : Ok : Ok : 4CF43ACF :00160000:ROM translator SA images
0107: 0 : Dd :105039: 1:Yes : Ok : Ok : 376C4F07 :00020000:ROM module image
0107: 1 : Dd :105039: 1:Yes : Ok : Ok : 376C4F07 :00020000:ROM module image
0106: 0 : Dd :105038: 1:Yes : Ok : Ok : 4919B20C :000200CC:ROM module image
0106: 1 : Dd :105038: 1:Yes : Ok : Ok : 4919B20C :000200CC:ROM module image
0108: 0 : Dr : 38: 33:Yes : Ok : Ok : AAC4ADC8 :000200CC:IBI packet
0108: 1 : Dr : 38: 33:Yes : Ok : Ok : AAC4ADC8 :000200CC:IBI packet
0002: 0 : B :105107: 3:Yes : Ok : Ok : 269536CA :00080000:Configuration (HDD ID)
0002: 1 : B :105107: 3:Yes : Ok : Ok : 269536CA :00080000:Configuration (HDD ID)
0017: 0 : B :105110: 63:Yes : Ok : Ok : 7C92E13B :000200CC:Loaded part of microprogram code
0017: 1 : B :105110: 63:Yes : Ok : Ok : 7C92E13B :000200CC:Loaded part of microprogram code
001B: 0 : B :105173: 111:Yes : Ok : Ok : B472FCAD :000200CC:Loaded part of microprogram code
001B: 1 : B :105173: 111:Yes : Ok : Ok : B472FCAD :000200CC:Loaded part of microprogram code
001C: 0 : B :105284: 48:Yes : Ok : Ok : A3A464DC :000200CC:Loaded part of microprogram code
001C: 1 : B :105284: 48:Yes : Ok : Ok : A3A464DC :000200CC:Loaded part of microprogram code
0014: 0 : B :105332: 27:Yes : Ok : Ok : 998653B8 :000200CC:Loaded part of microprogram code
0014: 1 : B :105332: 27:Yes : Ok : Ok : 998653B8 :000200CC:Loaded part of microprogram code
0015: 0 : B :105359: 16:Yes : Ok : Ok : 544BBE27 :000200CC:Loaded part of microprogram code
0015: 1 : B :105359: 16:Yes : Ok : Ok : 544BBE27 :000200CC:Loaded part of microprogram code
001E: 0 : B :105375: 22:Yes : Ok : Ok : 28AF28EB :000200CC:Loaded part of microprogram code
001E: 1 : B :105375: 22:Yes : Ok : Ok : 28AF28EB :000200CC:Loaded part of microprogram code
002F: 0 : B :105397: 6:Yes : Ok : Ok : 3C46BB6E :000200CC:Loaded part of microprogram code
002F: 1 : B :105397: 6:Yes : Ok : Ok : 3C46BB6E :000200CC:Loaded part of microprogram code
002A: 0 : B :105403: 6:Yes : Ok : Ok : 33AA2B6F :000200CC:Loaded part of microprogram code
002A: 1 : B :105403: 6:Yes : Ok : Ok : 33AA2B6F :000200CC:Loaded part of microprogram code
0021: 0 : B :105409: 75:Yes : Ok : Ok : 99576A89 :0081000F:S.M.A.R.T.
0021: 1 : B :105409: 75:Yes : Ok : Ok : 99576A89 :0081000F:S.M.A.R.T.
0022: 0 : B :105484: 75:Yes : Ok : Ok : 99576A88 :0081000F:S.M.A.R.T.
0022: 1 : B :105484: 75:Yes : Ok : Ok : 99576A88 :0081000F:S.M.A.R.T.
0023: 0 : B :105559: 75:Yes : Ok : Ok : 4A22F9CE :0081000F:S.M.A.R.T. Log (reserved)
0023: 1 : B :105559: 75:Yes : Ok : Ok : 4A22F9CE :0081000F:S.M.A.R.T. Log (reserved)
0024: 0 : B :105634: 75:Yes : Ok : Ok : 7DF433CD :0081000F:S.M.A.R.T. Log (reserved)
0024: 1 : B :105634: 75:Yes : Ok : Ok : 7DF433CD :0081000F:S.M.A.R.T. Log (reserved)
0013: 0 : B :105709: 56:Yes : Ok : Ok : 8CBFFBBF :000200CC:Loaded part of microprogram code
0013: 1 : B :105709: 56:Yes : Ok : Ok : 8CBFFBBF :000200CC:Loaded part of microprogram code
0080: 0 : B :105765: 9:Yes : Ok : Ok : 61F7E9EA :000200CC:Loaded part of microprogram code
0080: 1 : B :105765: 9:Yes : Ok : Ok : 61F7E9EA :000200CC:Loaded part of microprogram code
0011: 0 : B :105774: 430:Yes : Ok : Ok : 40BE98A5 :000200CC:Loaded part of microprogram code
0011: 1 : B :105774: 430:Yes : Ok : Ok : 40BE98A5 :000200CC:Loaded part of microprogram code
0019: 0 : B :106204: 31:Yes : Ok : Ok : 3DAD2BEC :000200CC:Loaded part of microprogram code
0019: 1 : B :106204: 31:Yes : Ok : Ok : 3DAD2BEC :000200CC:Loaded part of microprogram code
0012: 0 : B :106235: 52:Yes : Ok : Ok : D5BC9F84 :000200CC:Loaded part of microprogram code
0012: 1 : B :106235: 52:Yes : Ok : Ok : D5BC9F84 :000200CC:Loaded part of microprogram code
0050: 0 : As :106287: 3:Yes : Ok : Ok : 48A645FE :000200CC:Parameters table 1
0050: 1 : As :106287: 3:Yes : Ok : Ok : 48A645FE :000200CC:Parameters table 1
0051: 0 : As :106290: 3:Yes : Ok : Ok : 323E15CE :000200CC:Parameters table 2
0051: 1 : As :106290: 3:Yes : Ok : Ok : 323E15CE :000200CC:Parameters table 2
0052: 0 : As :106293: 3:Yes : Ok : Ok : 48A645FC :000200CC:Parameters table 3
0052: 1 : As :106293: 3:Yes : Ok : Ok : 48A645FC :000200CC:Parameters table 3
0053: 0 : As :106296: 3:Yes : Ok : Ok : 323E15CC :000200CC:Parameters table 4
0053: 1 : As :106296: 3:Yes : Ok : Ok : 323E15CC :000200CC:Parameters table 4
0061: 0 : B :106299: 29:Yes : Ok : Ok : B9FB5D26 :000200CC:Loaded part of microprogram code
0061: 1 : B :106299: 29:Yes : Ok : Ok : B9FB5D26 :000200CC:Loaded part of microprogram code
0062: 0 : :106328: 1:Yes : Ok : Ok : 520E48E4 :00010000:
0062: 1 : :106328: 1:Yes : Ok : Ok : 520E48E4 :00010000:
001F: 0 : B :106329: 20:Yes : Ok : Ok : 49E0D241 :000200CC:Loaded part of microprogram code
001F: 1 : B :106329: 20:Yes : Ok : Ok : 49E0D241 :000200CC:Loaded part of microprogram code
006E: 0 : B :106349: 2:Yes : Ok : Ok : 375605E8 :000200CC:Loaded part of microprogram code
006E: 1 : B :106349: 2:Yes : Ok : Ok : 375605E8 :000200CC:Loaded part of microprogram code
0116: 0 : : 6048: 6:Yes : Ok : Ok : 3DF64830 :000200CC:
0116: 1 : : 6048: 6:Yes : Ok : Ok : 3DF64830 :000200CC:
0118: 0 : : 6054: 20:Yes : Ok : Ok : AE8DEA56 :000200CC:
0118: 1 : : 6054: 20:Yes : Ok : Ok : AE8DEA56 :000200CC:
AC55: 0 : :106377: 1:Yes : Ok : Ok : 3DFA9CF1 :000200CC:
AC55: 1 : :106377: 1:Yes : Ok : Ok : 3DFA9CF1 :000200CC:
4002: 0 : :106378: 1:Yes : Ok : Ok : 5C080663 :000200CC:
4002: 1 : :106378: 1:Yes : Ok : Ok : 5C080663 :000200CC:
0109: 0 : Dd : 71: 385:Yes : Ok : Ok : B1F4FF9E :00010000:ROM image
0109: 1 : Dd : 71: 385:Yes : Ok : Ok : B1F4FF9E :00010000:ROM image
0121: 0 : : 96845:8193:Yes : Ok : Ok : 00000000 :NOT_INIT:
0121: 1 : : 96845:8193:Yes : Ok : Ok : DFEA11F5 :NOT_INIT:
3604: 0 : : 96746: 16:Yes : Ok : Ok : D3B73420 :NOT_INIT:
3604: 1 : : 96746: 16:Yes : Ok : Ok : D3B73420 :NOT_INIT:
0033: 0 : Dd : 456:1423:Yes : Ok : Ok : 80D5C436 :00150000:P-List (Primary defect list)
0033: 1 : Dd : 456:1423:Yes : Ok : Ok : 80D5C436 :00150000:P-List (Primary defect list)
0031: 0 : Ad : 1879: 924:Yes : Ok : Ok : EE2BE331 :00250000:Translator
0031: 1 : Ad : 1879: 924:Yes : Ok : Ok : EE2BE331 :00250000:Translator
000C: 0 : B : 2803: 5:Yes : Ok : Ok : 828C4BC8 :00010100:Models table
000C: 1 : B : 2803: 5:Yes : Ok : Ok : 828C4BC8 :00010100:Models table
0034: 0 : C : 2808: 23:Yes : Ok : Ok : 4DF74912 :00150000:G-List (Grown defect list)
0034: 1 : C : 2808: 23:Yes : Ok : Ok : 4DF74912 :00150000:G-List (Grown defect list)
0032: 0 : B : 2831: 32:Yes : Ok : Ok : 0D3238DD :00170000:Relo Bad Block Module
0032: 1 : B : 2831: 32:Yes : Ok : Ok : 0D3238DD :00170000:Relo Bad Block Module
0036: 0 : Ad : 2863: 9:Yes : Ok : Ok : 5171FC5B :00010000:T-List Module
0036: 1 : Ad : 2863: 9:Yes : Ok : Ok : 5171FC5B :00010000:T-List Module
0029: 0 : B : 2872: 6:Yes : Ok : Ok : 46ABEDB6 :00010000:Loaded part of microprogram code
0029: 1 : B : 2872: 6:Yes : Ok : Ok : 46ABEDB6 :00010000:Loaded part of microprogram code
0040: 0 : As : 2878: 125:Yes : Ok : Ok : 05FB59CA :00010000:Adaptive data
0040: 1 : As : 2878: 125:Yes : Ok : Ok : 05FB59CA :00010000:Adaptive data
0041: 0 : As : 3003: 125:Yes : Ok : Ok : DEE36B26 :00010000:Adaptive data
0041: 1 : As : 3003: 125:Yes : Ok : Ok : DEE36B26 :00010000:Adaptive data
0042: 0 : As : 3128: 125:Yes : Ok : Ok : DEE36B25 :00010000:Adaptive data
0042: 1 : As : 3128: 125:Yes : Ok : Ok : DEE36B25 :00010000:Adaptive data
0043: 0 : As : 3253: 125:Yes : Ok : Ok : DEE36B24 :00010000:Adaptive data
0043: 1 : As : 3253: 125:Yes : Ok : Ok : DEE36B24 :00010000:Adaptive data
004E: 0 : B : 3378: 46:Yes : Ok : Ok : A667D87A :000200CC:Loaded part of microprogram code
004E: 1 : B : 3378: 46:Yes : Ok : Ok : A667D87A :000200CC:Loaded part of microprogram code
0049: 0 : As : 3424: 3:Yes : Ok : Ok : E8CF65E0 :00010000:Adaptive data
0049: 1 : As : 3424: 3:Yes : Ok : Ok : E8CF65E0 :00010000:Adaptive data
004A: 0 : As : 3427: 26:Yes : Ok : Ok : 40179327 :00010000:Adaptive data
004A: 1 : As : 3427: 26:Yes : Ok : Ok : 40179327 :00010000:Adaptive data
004D: 0 : As : 3453: 1:Yes : Ok : Ok : 520E48F9 :00010000:Adaptive data
004D: 1 : As : 3453: 1:Yes : Ok : Ok : 520E48F9 :00010000:Adaptive data
0003: 0 : As : 3454: 27:Yes : Ok : Ok : 8A122F9B :00020000:Format Select Data Module
0003: 1 : As : 3454: 27:Yes : Ok : Ok : 8A122F9B :00020000:Format Select Data Module
0004: 0 : B : 3481: 393:Yes : Ok : Ok : 9B46B1A9 :00020000:Family models configuration (Main)
0004: 1 : B : 3481: 393:Yes : Ok : Ok : 9B46B1A9 :00020000:Family models configuration (Main)
0025: 0 : : 3874: 257:Yes : Ok : Ok : 3CFB4921 :000200CC:
0025: 1 : : 3874: 257:Yes : Ok : Ok : 3CFB4921 :000200CC:
0026: 0 : : 4131: 129:Yes : Ok : Ok : 3D7B4920 :000200CC:
0026: 1 : : 4131: 129:Yes : Ok : Ok : 3D7B4920 :000200CC:
0038: 0 : B : 4260: 257:Yes : Ok : Ok : 3CFB490E :000200CC:Loaded part of microprogram code
0038: 1 : B : 4260: 257:Yes : Ok : Ok : 3CFB490E :000200CC:Loaded part of microprogram code
0039: 0 : B : 4517: 17:Yes : Ok : Ok : 3DEB490D :000200CC:Loaded part of microprogram code
0039: 1 : B : 4517: 17:Yes : Ok : Ok : 3DEB490D :000200CC:Loaded part of microprogram code
0037: 0 : Dr : 4534: 1:Yes : Ok : Ok : 44A03CDB :00010000:Gain Call Data Module
0037: 1 : Dr : 4534: 1:Yes : Ok : Ok : 44A03CDB :00010000:Gain Call Data Module
002D: 0 : Dr : 4535: 308:Yes : Ok : Ok : 3CC84919 :000200CC:Debug Log
002D: 1 : Dr : 4535: 308:Yes : Ok : Ok : 3CC84919 :000200CC:Debug Log
002E: 0 : B : 4843: 308:Yes : Ok : Ok : 3CC84918 :000200CC:Loaded part of microprogram code
002E: 1 : B : 4843: 308:Yes : Ok : Ok : 3CC84918 :000200CC:Loaded part of microprogram code
00B5: 0 : Dr : 5151: 160:Yes : Ok : Ok : 72DA141A :000200CC:WRRO Log Module
00B5: 1 : Dr : 5151: 160:Yes : Ok : Ok : 72DA141A :000200CC:WRRO Log Module
006B: 0 : B : 5311: 4:Yes : Ok : Ok : 5C4EC7B3 :000200CC:Loaded part of microprogram code
006B: 1 : B : 5311: 4:Yes : Ok : Ok : 5C4EC7B3 :000200CC:Loaded part of microprogram code
003A: 0 : : 5315: 3:Yes : Ok : Ok : D4255394 :00000100:
003A: 1 : : 5315: 3:Yes : Ok : Ok : D4255394 :00000100:
0028: 0 : Dr : 5318: 16:Yes : Ok : Ok : 15E8F033 :00030000:Factory Self Test script
0028: 1 : Dr : 5318: 16:Yes : Ok : Ok : 15E8F033 :00030000:Factory Self Test script
003B: 0 : : 5334: 16:Yes : Ok : Ok : 4F7548A1 :00030000:
003B: 1 : : 5334: 16:Yes : Ok : Ok : 4F7548A1 :00030000:
003C: 0 : : 5350: 16:Yes : Ok : Ok : 4F44423F :00030000:
003C: 1 : : 5350: 16:Yes : Ok : Ok : 4F44423F :00030000:
003D: 0 : : 5366: 16:Yes : Ok : Ok : 4F44423E :00030000:
003D: 1 : : 5366: 16:Yes : Ok : Ok : 4F44423E :00030000:
003E: 0 : : 5382: 16:Yes : Ok : Ok : 4F44423D :00030000:
003E: 1 : : 5382: 16:Yes : Ok : Ok : 4F44423D :00030000:
003F: 0 : : 5398: 16:Yes : Ok : Ok : 4F44423C :00030000:
003F: 1 : : 5398: 16:Yes : Ok : Ok : 4F44423C :00030000:
006F: 0 : B : 5415: 633:Yes : Ok :Error:4D5204EA/0D5083CE:AOZ30000:Loaded part of microprogram code
006F: 1 : B : 5415: 633:Yes : Ok :Error:4D5204EA/0D5083CE:AOZ30000:Loaded part of microprogram code
0119: 0 : : 6074: 5:Yes : Ok : Ok : 8337775A :0100....:
0119: 1 : : 6074: 5:Yes : Ok : Ok : 8337775A :0100....:
0068: 0 : : 6079: 75:Yes : Ok : Ok : 56DF5A8D :0081000F:
0068: 1 : : 6079: 75:Yes : Ok : Ok : 56DF5A8D :0081000F:
0069: 0 : : 6154: 75:Yes : Ok : Ok : 4A24A988 :0081000F:
0069: 1 : : 6154: 75:Yes : Ok : Ok : 4A24A988 :0081000F:
006A: 0 : : 6229: 75:Yes : Ok : Ok : 4A24A987 :0081000F:
006A: 1 : : 6229: 75:Yes : Ok : Ok : 4A24A987 :0081000F:
0115: 0 : :106707: 57:Yes : Ok : Ok : 124B1941 :........:
0115: 1 : :106707: 57:Yes : Ok : Ok : 124B1941 :........:
00DE: 0 : Dr : 6309: 207:Yes : Ok : Ok : 97962D8A :1013-B34:Factory Self Test module
00DE: 1 : Dr : 6309: 207:Yes : Ok : Ok : 97962D8A :1013-B34:Factory Self Test module
00B6: 0 : Dr : 6516: 192:Yes : Ok : Ok : 5BD04E4D :1013-B34:Factory Self Test module
00B6: 1 : Dr : 6516: 192:Yes : Ok : Ok : 5BD04E4D :1013-B34:Factory Self Test module
00D5: 0 : Dr : 6708: 183:Yes : Ok : Ok : DF1DAF3D :1013-B34:Factory Self Test module
00D5: 1 : Dr : 6708: 183:Yes : Ok : Ok : DF1DAF3D :1013-B34:Factory Self Test module
3411: 0 : : 6891: 119:Yes : Ok : Ok : 327DAC98 :1013-B34:
3411: 1 : : 6891: 119:Yes : Ok : Ok : 327DAC98 :1013-B34:
00D1: 0 : : 7010: 226:Yes : Ok : Ok : A6B99515 :1013-B34:
00D1: 1 : : 7010: 226:Yes : Ok : Ok : A6B99515 :1013-B34:
00DB: 0 : Dr : 7236: 196:Yes : Ok : Ok : 3EA92565 :1013-B34:Factory Self Test module
00DB: 1 : Dr : 7236: 196:Yes : Ok : Ok : 3EA92565 :1013-B34:Factory Self Test module
00DF: 0 : Dr : 7432: 223:Yes : Ok : Ok : FE69FF86 :1013-B34:Factory Self Test module
00DF: 1 : Dr : 7432: 223:Yes : Ok : Ok : FE69FF86 :1013-B34:Factory Self Test module
00DD: 0 : Dr : 7655: 189:Yes : Ok : Ok : D47EC2C9 :1013-B34:Factory Self Test module
00DD: 1 : Dr : 7655: 189:Yes : Ok : Ok : D47EC2C9 :1013-B34:Factory Self Test module
00D6: 0 : Dr : 7844: 192:Yes : Ok : Ok : A7C50CC3 :1013-B34:Factory Self Test module
00D6: 1 : Dr : 7844: 192:Yes : Ok : Ok : A7C50CC3 :1013-B34:Factory Self Test module
3402: 0 : : 8036: 199:Yes : Ok : Ok : 1CAAD639 :1013-B34:
3402: 1 : : 8036: 199:Yes : Ok : Ok : 1CAAD639 :1013-B34:
00D7: 0 : Dr : 8235: 193:Yes : Ok : Ok : 62BF0E08 :1013-B34:Factory Self Test module
00D7: 1 : Dr : 8235: 193:Yes : Ok : Ok : 62BF0E08 :1013-B34:Factory Self Test module
00D2: 0 : Dr : 8428: 133:Yes : Ok : Ok : 95EF8FE2 :1013-B34:Factory Self Test module
00D2: 1 : Dr : 8428: 133:Yes : Ok : Ok : 95EF8FE2 :1013-B34:Factory Self Test module
3300: 0 : : 8561: 136:Yes : Ok : Ok : 40EB8BFC :1013-B34:
3300: 1 : : 8561: 136:Yes : Ok : Ok : 40EB8BFC :1013-B34:
3301: 0 : : 8697: 128:Yes : Ok : Ok : 42E43B0A :1013-B34:
3301: 1 : : 8697: 128:Yes : Ok : Ok : 42E43B0A :1013-B34:
3400: 0 : : 8825: 166:Yes : Ok : Ok : D0CCC86C :1013-B34:
3400: 1 : : 8825: 166:Yes : Ok : Ok : D0CCC86C :1013-B34:
00BB: 0 : Dr : 8991: 152:Yes : Ok : Ok : D2866137 :1013-B34:Factory Self Test module
00BB: 1 : Dr : 8991: 152:Yes : Ok : Ok : D2866137 :1013-B34:Factory Self Test module
3405: 0 : : 9143: 158:Yes : Ok : Ok : 0A5E0C91 :1013-B34:
3405: 1 : : 9143: 158:Yes : Ok : Ok : 0A5E0C91 :1013-B34:
00D9: 0 : Dr : 9301: 188:Yes : Ok : Ok : FBBB63E5 :1013-B34:Factory Self Test module
00D9: 1 : Dr : 9301: 188:Yes : Ok : Ok : FBBB63E5 :1013-B34:Factory Self Test module
00D4: 0 : Dr : 9489: 132:Yes : Ok : Ok : 2C22F7ED :1013-B34:Factory Self Test module
00D4: 1 : Dr : 9489: 132:Yes : Ok : Ok : 2C22F7ED :1013-B34:Factory Self Test module
00DC: 0 : Dr : 9621: 140:Yes : Ok : Ok : EA1C55A2 :1013-B34:Factory Self Test module
00DC: 1 : Dr : 9621: 140:Yes : Ok : Ok : EA1C55A2 :1013-B34:Factory Self Test module
00D0: 0 : Dr : 9761: 136:Yes : Ok : Ok : 72CBEC11 :1013-B34:Factory Self Test module
00D0: 1 : Dr : 9761: 136:Yes : Ok : Ok : 72CBEC11 :1013-B34:Factory Self Test module
00D3: 0 : Dr : 9897: 118:Yes : Ok : Ok : 9F7B3BCA :1013-B34:Factory Self Test module
00D3: 1 : Dr : 9897: 118:Yes : Ok : Ok : 9F7B3BCA :1013-B34:Factory Self Test module
00F7: 0 : : 10015: 188:Yes : Ok : Ok : 97D04F70 :1013-B34:
00F7: 1 : : 10015: 188:Yes : Ok : Ok : 97D04F70 :1013-B34:
00BA: 0 : Dr : 10203: 162:Yes : Ok : Ok : E11DAFA7 :1013-B34:Factory Self Test module
00BA: 1 : Dr : 10203: 162:Yes : Ok : Ok : E11DAFA7 :1013-B34:Factory Self Test module
3406: 0 : : 10365: 154:Yes : Ok : Ok : 92F83300 :1013-B34:
3406: 1 : : 10365: 154:Yes : Ok : Ok : 92F83300 :1013-B34:
00B9: 0 : Dr : 10519: 158:Yes : Ok : Ok : 46A70503 :1013-B34:Factory Self Test module
00B9: 1 : Dr : 10519: 158:Yes : Ok : Ok : 46A70503 :1013-B34:Factory Self Test module
00BC: 0 : Dr : 10677: 154:Yes : Ok : Ok : CEB891B5 :1013-B34:Factory Self Test module
00BC: 1 : Dr : 10677: 154:Yes : Ok : Ok : CEB891B5 :1013-B34:Factory Self Test module
00D8: 0 : Dr : 10831: 121:Yes : Ok : Ok : C2C01D52 :1013-B34:Factory Self Test module
00D8: 1 : Dr : 10831: 121:Yes : Ok : Ok : C2C01D52 :1013-B34:Factory Self Test module
00BD: 0 : : 10952: 223:Yes : Ok : Ok : 7CF84BC8 :1013-B34:
00BD: 1 : : 10952: 223:Yes : Ok : Ok : 7CF84BC8 :1013-B34:
00BE: 0 : Dr : 11175: 27:Yes : Ok : Ok : 1440A8D3 :1013-B34:Factory Self Test module
00BE: 1 : Dr : 11175: 27:Yes : Ok : Ok : 1440A8D3 :1013-B34:Factory Self Test module
3401: 0 : : 11202: 152:Yes : Ok : Ok : E082CED2 :1013-B34:
3401: 1 : : 11202: 152:Yes : Ok : Ok : E082CED2 :1013-B34:
3302: 0 : : 11354: 136:Yes : Ok : Ok : CD05215F :1013-B34:
3302: 1 : : 11354: 136:Yes : Ok : Ok : CD05215F :1013-B34:
3416: 0 : : 11490: 141:Yes : Ok : Ok : 92CADC41 :1013-B34:
3416: 1 : : 11490: 141:Yes : Ok : Ok : 92CADC41 :1013-B34:
3F01: 0 : : 11631: 8:Yes : Ok : Ok : 3C02F845 :1013-B34:
3F01: 1 : : 11631: 8:Yes : Ok : Ok : 3C02F845 :1013-B34:
00B8: 0 : Dr : 11639: 2:Yes : Ok : Ok : 480434C0 :1013-B34:Single Plug Test Communication Module
00B8: 1 : Dr : 11639: 2:Yes : Ok : Ok : 480434C0 :1013-B34:Single Plug Test Communication Module
00BF: 0 : Dr : 11641: 8:Yes : Ok : Ok : 3C033687 :1013-B34:Factory Self Test module
00BF: 1 : Dr : 11641: 8:Yes : Ok : Ok : 3C033687 :1013-B34:Factory Self Test module
00E6: 0 : Dr : 11649: 64:Yes : Ok : Ok : 7294623E :1013-B34:Factory Self Test log
00E6: 1 : Dr : 11649: 64:Yes : Ok : Ok : 7294623E :1013-B34:Factory Self Test log
00E7: 0 : Dr : 11713: 32:Yes : Ok : Ok : B9E8D6F4 :1013-B34:Factory Self Test parameters module
00E7: 1 : Dr : 11713: 32:Yes : Ok : Ok : B9E8D6F4 :1013-B34:Factory Self Test parameters module
00B7: 0 : Dr :105070: 18:Yes : Ok : Ok : FFD9125F :NOT_INIT:Test Clamp Data
00B7: 1 : Dr :105070: 18:Yes : Ok : Ok : FFD9125F :NOT_INIT:Test Clamp Data
00FA: 0 : Dr :106379: 256:Yes : Ok : Ok : FEEB121C :NOT_INIT:Butterfly Log
00FA: 1 : Dr :106379: 256:Yes : Ok : Ok : FEEB121C :NOT_INIT:Butterfly Log
00FC: 0 : Dr : 34: 4:Yes : Ok : Ok : FFE7121A :NOT_INIT:Factory Self Test module
00FC: 1 : Dr : 34: 4:Yes : Ok : Ok : FFE7121A :NOT_INIT:Factory Self Test module
00FD: 0 : Dr : 12296: 64:Yes : Ok : Ok : 3F913476 :1013-B34:Factory Self Test module
00FD: 1 : Dr : 12296: 64:Yes : Ok : Ok : 3F913476 :1013-B34:Factory Self Test module
00EE: 0 : Dr :106351: 5:Yes : Ok : Ok : 4A01C554 :1013-B34:RRO Data Log
00EE: 1 : Dr :106351: 5:Yes : Ok : Ok : 4A01C554 :1013-B34:RRO Data Log
3E00: 0 : :105088: 5:Yes : Ok : Ok : 4B17F102 :1013-B34:
3E00: 1 : :105088: 5:Yes : Ok : Ok : 4B17F102 :1013-B34:
3801: 0 : : 11745: 32:Yes : Ok : Ok : 2FDDD648 :1013-B34:
3801: 1 : : 11745: 32:Yes : Ok : Ok : 2FDDD648 :1013-B34:
3C00: 0 : :106635: 32:Yes : Ok : Ok : FFCAD716 :NOT_INIT:
3C00: 1 : :106635: 32:Yes : Ok : Ok : FFCAD716 :NOT_INIT:
3415: 0 : : 11777: 364:Yes : Ok : Ok : 5FBC55AE :1013-B34:
3415: 1 : : 11777: 364:Yes : Ok : Ok : 5FBC55AE :1013-B34:
3500: 0 : : 12141: 154:Yes : Ok : Ok : B47D9516 :1013-B34:
3500: 1 : : 12141: 154:Yes : Ok : Ok : B47D9516 :1013-B34:
3F00: 0 : : 12295: 1:Yes : Ok : Ok : 4C09F846 :1013-B34:
3F00: 1 : : 12295: 1:Yes : Ok : Ok : 4C09F846 :1013-B34:
00C4: 0 : Dr : 12363: 228:Yes : Ok : Ok : 580640F9 :FD.0011 :Calibrations module
00C4: 1 : Dr : 12363: 228:Yes : Ok : Ok : 580640F9 :FD.0011 :Calibrations module
00A8: 0 : : 12591: 163:Yes : Ok : Ok : 7379644A :FD.0011 :
00A8: 1 : : 12591: 163:Yes : Ok : Ok : 7379644A :FD.0011 :
00A2: 0 : : 12754: 217:Yes : Ok : Ok : FD8FB503 :FD.0011 :
00A2: 1 : : 12754: 217:Yes : Ok : Ok : FD8FB503 :FD.0011 :
00C5: 0 : Dr : 12971: 76:Yes : Ok : Ok : 46CBF654 :FD.AF05 :Calibration script (DCM)
00C5: 1 : Dr : 12971: 76:Yes : Ok : Ok : 46CBF654 :FD.AF05 :Calibration script (DCM)
00C3: 0 : : 96193: 192:Yes : Ok : Ok : 2F5A50D8 :FD.0011 :
00C3: 1 : : 96193: 192:Yes : Ok : Ok : 2F5A50D8 :FD.0011 :
00C8: 0 : : 96385: 230:Yes : Ok : Ok : 127B7693 :FD.0011 :
00C8: 1 : : 96385: 230:Yes : Ok : Ok : 127B7693 :FD.0011 :
0091: 0 : Dr : 96615: 4:Yes : Ok : Ok : 29ADC744 :FD.0011 :Calibrations module
0091: 1 : Dr : 96615: 4:Yes : Ok : Ok : 29ADC744 :FD.0011 :Calibrations module
00CC: 0 : Dr :106695: 12:Yes : Ok : Ok : FFDF124A :NOT_INIT:Calibrations module
00CC: 1 : Dr :106695: 12:Yes : Ok : Ok : FFDF124A :NOT_INIT:Calibrations module
00CA: 0 : Dr :106683: 12:Yes : Ok : Ok : 3A42B248 :NOT_INIT:Calibrations module
00CA: 1 : Dr :106683: 12:Yes : Ok : Ok : 3A42B248 :NOT_INIT:Calibrations module
0099: 0 : :106671: 12:Yes : Ok : Ok : FFDF127D :NOT_INIT:
0099: 1 : :106671: 12:Yes : Ok : Ok : FFDF127D :NOT_INIT:
0098: 0 : : 95479: 24:Yes : Ok : Ok : FFD3127E :NOT_INIT:
0098: 1 : : 95479: 24:Yes : Ok : Ok : FFD3127E :NOT_INIT:
00CB: 0 : Dr :106365: 12:Yes : Ok : Ok : FFDF124B :NOT_INIT:Calibrations module
00CB: 1 : Dr :106365: 12:Yes : Ok : Ok : FFDF124B :NOT_INIT:Calibrations module
00CD: 0 : Dr :105095: 12:Yes : Ok : Ok : FFDF1249 :NOT_INIT:Calibrations module
00CD: 1 : Dr :105095: 12:Yes : Ok : Ok : FFDF1249 :NOT_INIT:Calibrations module
00CF: 0 : Dr : 95467: 12:Yes : Ok : Ok : EDFEC6EB :NOT_INIT:Calibrations module
00CF: 1 : Dr : 95467: 12:Yes : Ok : Ok : EDFEC6EB :NOT_INIT:Calibrations module
00CE: 0 : Dr : 95455: 12:Yes : Ok : Ok : D6F7B596 :NOT_INIT:Calibrations module
00CE: 1 : Dr : 95455: 12:Yes : Ok : Ok : D6F7B596 :NOT_INIT:Calibrations module
0093: 0 : Dr : 95443: 12:Yes : Ok : Ok : FFDF1283 :NOT_INIT:Calibrations module
0093: 1 : Dr : 95443: 12:Yes : Ok : Ok : FFDF1283 :NOT_INIT:Calibrations module
00C1: 0 : Dr :106670: 1:Yes : Ok : Ok : F9D07690 :NOT_INIT:Calibrations module
00C1: 1 : Dr :106670: 1:Yes : Ok : Ok : F9D07690 :NOT_INIT:Calibrations module
00C2: 0 : Dr : 96619: 2:Yes : Ok : Ok : 630D346D :FD.0011 :Calibrations module
00C2: 1 : Dr : 96619: 2:Yes : Ok : Ok : 630D346D :FD.0011 :Calibrations module
00C7: 0 : Dr :106669: 1:Yes : Ok : Ok : FFEA124F :NOT_INIT:Calibrations module
00C7: 1 : Dr :106669: 1:Yes : Ok : Ok : FFEA124F :NOT_INIT:Calibrations module
009E: 0 : Dr :106360: 5:Yes : Ok : Ok : B631CA66 :NOT_INIT:Calibrations module
009E: 1 : Dr :106360: 5:Yes : Ok : Ok : B631CA66 :NOT_INIT:Calibrations module
00C6: 0 : : 95388: 55:Yes : Ok : Ok : 83EA3DE9 :NOT_INIT:
00C6: 1 : : 95388: 55:Yes : Ok : Ok : 83EA3DE9 :NOT_INIT:
00C9: 0 : : 95324: 64:Yes : Ok : Ok : BBB3AF4A :NOT_INIT:
00C9: 1 : : 95324: 64:Yes : Ok : Ok : BBB3AF4A :NOT_INIT:
0094: 0 : : 95314: 10:Yes : Ok : Ok : FFE11282 :NOT_INIT:
0094: 1 : : 95314: 10:Yes : Ok : Ok : FFE11282 :NOT_INIT:
0096: 0 : : 95194: 120:Yes : Ok : Ok : 7156CB7D :NOT_INIT:
0096: 1 : : 95194: 120:Yes : Ok : Ok : 7156CB7D :NOT_INIT:
0097: 0 : : 95170: 24:Yes : Ok : Ok : FFD3127F :NOT_INIT:
0097: 1 : : 95170: 24:Yes : Ok : Ok : FFD3127F :NOT_INIT:
00AA: 0 : : 96621: 125:Yes : Ok : Ok : E254C8D8 :FD.0011 :
00AA: 1 : : 96621: 125:Yes : Ok : Ok : E254C8D8 :FD.0011 :
00A9: 0 : : 95050: 120:Yes : Ok : Ok : 51D5C988 :NOT_INIT:
00A9: 1 : : 95050: 120:Yes : Ok : Ok : 51D5C988 :NOT_INIT:
00A5: 0 : : 95035: 15:Yes : Ok : Ok : FFDC1271 :NOT_INIT:
00A5: 1 : : 95035: 15:Yes : Ok : Ok : FFDC1271 :NOT_INIT:
00A6: 0 : : 94675: 360:Yes : Ok : Ok : FE831270 :NOT_INIT:
00A6: 1 : : 94675: 360:Yes : Ok : Ok : FE831270 :NOT_INIT:
0092: 0 : Dr : 94625: 50:Yes : Ok : Ok : FFB91284 :NOT_INIT:Calibrations module
0092: 1 : Dr : 94625: 50:Yes : Ok : Ok : FFB91284 :NOT_INIT:Calibrations module
00A0: 0 : : 94561: 64:Yes : Ok : Ok : 7B0E2B7A :NOT_INIT:
00A0: 1 : : 94561: 64:Yes : Ok : Ok : 7B0E2B7A :NOT_INIT:
00A1: 0 : : 13047: 99:Yes : Ok : Ok : 7FEC8E41 :FD.0011 :
00A1: 1 : : 13047: 99:Yes : Ok : Ok : 7FEC8E41 :FD.0011 :
009A: 0 : : 94521: 40:Yes : Ok : Ok : 16AEFC78 :NOT_INIT:
009A: 1 : : 94521: 40:Yes : Ok : Ok : 16AEFC78 :NOT_INIT:
009C: 0 : :106668: 1:Yes : Ok : Ok : FFB57C46 :NOT_INIT:
009C: 1 : :106668: 1:Yes : Ok : Ok : FFB57C46 :NOT_INIT:
2000: 0 : : 92921:1600:Yes : Ok : Ok : D81FF0B9 :NOT_INIT:
2000: 1 : : 92921:1600:Yes : Ok : Ok : D81FF0B9 :NOT_INIT:
2001: 0 : : 91321:1600:Yes : Ok : Ok : F9AAF315 :NOT_INIT:
2001: 1 : : 91321:1600:Yes : Ok : Ok : F9AAF315 :NOT_INIT:
2002: 0 : : 89721:1600:Yes : Ok : Ok : F9AAF314 :NOT_INIT:
2002: 1 : : 89721:1600:Yes : Ok : Ok : F9AAF314 :NOT_INIT:
2003: 0 : : 88121:1600:Yes : Ok : Ok : F9AAF313 :NOT_INIT:
2003: 1 : : 88121:1600:Yes : Ok : Ok : F9AAF313 :NOT_INIT:
2004: 0 : : 86521:1600:Yes : Ok : Ok : F9AAF312 :NOT_INIT:
2004: 1 : : 86521:1600:Yes : Ok : Ok : F9AAF312 :NOT_INIT:
2005: 0 : : 84921:1600:Yes : Ok : Ok : F9AAF311 :NOT_INIT:
2005: 1 : : 84921:1600:Yes : Ok : Ok : F9AAF311 :NOT_INIT:
2006: 0 : : 83321:1600:Yes : Ok : Ok : F9AAF310 :NOT_INIT:
2006: 1 : : 83321:1600:Yes : Ok : Ok : F9AAF310 :NOT_INIT:
2007: 0 : : 81721:1600:Yes : Ok : Ok : F9AAF30F :NOT_INIT:
2007: 1 : : 81721:1600:Yes : Ok : Ok : F9AAF30F :NOT_INIT:
2020: 0 : : 81641: 80:Yes : Ok : Ok : 07C652CF :NOT_INIT:
2020: 1 : : 81641: 80:Yes : Ok : Ok : 07C652CF :NOT_INIT:
2021: 0 : : 81561: 80:Yes : Ok : Ok : FF9AF2F5 :NOT_INIT:
2021: 1 : : 81561: 80:Yes : Ok : Ok : FF9AF2F5 :NOT_INIT:
2022: 0 : : 81481: 80:Yes : Ok : Ok : FF9AF2F4 :NOT_INIT:
2022: 1 : : 81481: 80:Yes : Ok : Ok : FF9AF2F4 :NOT_INIT:
2023: 0 : : 81401: 80:Yes : Ok : Ok : FF9AF2F3 :NOT_INIT:
2023: 1 : : 81401: 80:Yes : Ok : Ok : FF9AF2F3 :NOT_INIT:
2024: 0 : : 81321: 80:Yes : Ok : Ok : FF9AF2F2 :NOT_INIT:
2024: 1 : : 81321: 80:Yes : Ok : Ok : FF9AF2F2 :NOT_INIT:
2025: 0 : : 81241: 80:Yes : Ok : Ok : FF9AF2F1 :NOT_INIT:
2025: 1 : : 81241: 80:Yes : Ok : Ok : FF9AF2F1 :NOT_INIT:
2026: 0 : : 81161: 80:Yes : Ok : Ok : FF9AF2F0 :NOT_INIT:
2026: 1 : : 81161: 80:Yes : Ok : Ok : FF9AF2F0 :NOT_INIT:
2027: 0 : : 81081: 80:Yes : Ok : Ok : FF9AF2EF :NOT_INIT:
2027: 1 : : 81081: 80:Yes : Ok : Ok : FF9AF2EF :NOT_INIT:
2030: 0 : : 80481: 600:Yes : Ok : Ok : 436F3BFB :NOT_INIT:
2030: 1 : : 80481: 600:Yes : Ok : Ok : 436F3BFB :NOT_INIT:
2031: 0 : : 79881: 600:Yes : Ok : Ok : FD92F2E5 :NOT_INIT:
2031: 1 : : 79881: 600:Yes : Ok : Ok : FD92F2E5 :NOT_INIT:
2032: 0 : : 79281: 600:Yes : Ok : Ok : FD92F2E4 :NOT_INIT:
2032: 1 : : 79281: 600:Yes : Ok : Ok : FD92F2E4 :NOT_INIT:
2033: 0 : : 78681: 600:Yes : Ok : Ok : FD92F2E3 :NOT_INIT:
2033: 1 : : 78681: 600:Yes : Ok : Ok : FD92F2E3 :NOT_INIT:
2034: 0 : : 78081: 600:Yes : Ok : Ok : FD92F2E2 :NOT_INIT:
2034: 1 : : 78081: 600:Yes : Ok : Ok : FD92F2E2 :NOT_INIT:
2035: 0 : : 77481: 600:Yes : Ok : Ok : FD92F2E1 :NOT_INIT:
2035: 1 : : 77481: 600:Yes : Ok : Ok : FD92F2E1 :NOT_INIT:
2036: 0 : : 76881: 600:Yes : Ok : Ok : FD92F2E0 :NOT_INIT:
2036: 1 : : 76881: 600:Yes : Ok : Ok : FD92F2E0 :NOT_INIT:
2037: 0 : : 76281: 600:Yes : Ok : Ok : FD92F2DF :NOT_INIT:
2037: 1 : : 76281: 600:Yes : Ok : Ok : FD92F2DF :NOT_INIT:
2010: 0 : : 76121: 160:Yes : Ok : Ok : 01E6B297 :NOT_INIT:
2010: 1 : : 76121: 160:Yes : Ok : Ok : 01E6B297 :NOT_INIT:
2011: 0 : : 75961: 160:Yes : Ok : Ok : FF4AF305 :NOT_INIT:
2011: 1 : : 75961: 160:Yes : Ok : Ok : FF4AF305 :NOT_INIT:
2012: 0 : : 75801: 160:Yes : Ok : Ok : FF4AF304 :NOT_INIT:
2012: 1 : : 75801: 160:Yes : Ok : Ok : FF4AF304 :NOT_INIT:
2013: 0 : : 75641: 160:Yes : Ok : Ok : FF4AF303 :NOT_INIT:
2013: 1 : : 75641: 160:Yes : Ok : Ok : FF4AF303 :NOT_INIT:
2014: 0 : : 75481: 160:Yes : Ok : Ok : FF4AF302 :NOT_INIT:
2014: 1 : : 75481: 160:Yes : Ok : Ok : FF4AF302 :NOT_INIT:
2015: 0 : : 75321: 160:Yes : Ok : Ok : FF4AF301 :NOT_INIT:
2015: 1 : : 75321: 160:Yes : Ok : Ok : FF4AF301 :NOT_INIT:
2016: 0 : : 75161: 160:Yes : Ok : Ok : FF4AF300 :NOT_INIT:
2016: 1 : : 75161: 160:Yes : Ok : Ok : FF4AF300 :NOT_INIT:
2017: 0 : : 75001: 160:Yes : Ok : Ok : FF4AF2FF :NOT_INIT:
2017: 1 : : 75001: 160:Yes : Ok : Ok : FF4AF2FF :NOT_INIT:
2040: 0 : : 74651: 350:Yes : Ok : Ok : FE8CF2D6 :NOT_INIT:
2040: 1 : : 74651: 350:Yes : Ok : Ok : FE8CF2D6 :NOT_INIT:
2041: 0 : : 74301: 350:Yes : Ok : Ok : FE8CF2D5 :NOT_INIT:
2041: 1 : : 74301: 350:Yes : Ok : Ok : FE8CF2D5 :NOT_INIT:
2042: 0 : : 73951: 350:Yes : Ok : Ok : FE8CF2D4 :NOT_INIT:
2042: 1 : : 73951: 350:Yes : Ok : Ok : FE8CF2D4 :NOT_INIT:
2043: 0 : : 73601: 350:Yes : Ok : Ok : FE8CF2D3 :NOT_INIT:
2043: 1 : : 73601: 350:Yes : Ok : Ok : FE8CF2D3 :NOT_INIT:
2044: 0 : : 73251: 350:Yes : Ok : Ok : FE8CF2D2 :NOT_INIT:
2044: 1 : : 73251: 350:Yes : Ok : Ok : FE8CF2D2 :NOT_INIT:
2045: 0 : : 72901: 350:Yes : Ok : Ok : FE8CF2D1 :NOT_INIT:
2045: 1 : : 72901: 350:Yes : Ok : Ok : FE8CF2D1 :NOT_INIT:
2046: 0 : : 72551: 350:Yes : Ok : Ok : FE8CF2D0 :NOT_INIT:
2046: 1 : : 72551: 350:Yes : Ok : Ok : FE8CF2D0 :NOT_INIT:
2047: 0 : : 72201: 350:Yes : Ok : Ok : FE8CF2CF :NOT_INIT:
2047: 1 : : 72201: 350:Yes : Ok : Ok : FE8CF2CF :NOT_INIT:
2050: 0 : : 72151: 50:Yes : Ok : Ok : 9B077E1B :NOT_INIT:
dmarques
Postby dmarques » 09.01.12, 16:01
And are you sure that your drive hasn't been on another DR company for example?
erick
Postby erick » 10.01.12, 16:32
datalabace wrote:And are you sure that your drive hasn't been on another DR company for example?
Hi. thanks for replay.. the customers say no other company was send it. the rare think is its detected show all moduls ok, but in DE show Erroro read any sector, if i run a Surface Verification send all erroros, il verify just 2536 Sectors and then can red it but obusly no data. its a realy rare case. any clue?
Thanks and Best Regards.
dmarques
Postby dmarques » 11.01.12, 14:11
I can think of a translator issue, but seems that translator is original.
Have you tried PCB + ROM swap just to despite any PCB issue?
erick
Postby erick » 11.01.12, 16:57
datalabace wrote:I can think of a translator issue, but seems that translator is original.
Hi.. yes. i have a similar disk and make swap. actually hot swap to but nothing.
