sn 1987 WD20EADS-00R6B0, spins down, wont ram edit
drdoc
Postby drdoc » 08.12.11, 05:24
spions down after a minute and enters kernel mode with err abr
no model number detected
wont edit head map
there are no loaders.
What now ?
Techno mode key
ROM version............................. : 96.34Q
ROM generation.......................... : 96.34Q
Link table version...................... : 01.1R.
Consolidated ROM version................ : 00960034
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 245 265 (24)
ROM Firmware version.................... : 00960034
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< attemmpt to edit ram head map
Lib:
Offset (hex): 4000000
Map Size: 8
RAM Range 4000000 (0186A0) reading error Device Error Detected: "VSCE KEY SECTOR MUST PRECEED DATA XFER REQUEST"
View ROM information
Firmware version........................ : 00960034
ROM Modules
0A : Heads map
0B : Flash ROM dir
20B : Flash ROM dir (ext)
30 : SA Translator
47 : SA Adaptives
0D : Flash configuration
4F : Microprogram version
SA Regions
N : ABA : Size
0 : 0 : 247 488
1 : 329 984 :
dmarques
Re: sn 1987 WD20EADS-00R6B0, spins down, wont ram edit
Postby dmarques » 14.12.11, 12:30
Is that Dragfly4 family?
Have you tried to upload loader and then head map in ram?
