Barracude 7200.10 ST3160815AS
EADR
Postby EADR » 22.08.11, 11:02
Hi All,
I currently have the above drive that after a spindle and head swap remains busy upon power up. The drive makes no abnormal noises during spin up, it just remains spinning and constantly busy. I have tried alternative heads and another spindle/chassis. but it remains the same.
Drive was initially received with a blown TVS and seized spindle (unusual on a single platter drive, but hey..) The drive was initially housed in an external case, which was dropped and subsequently stopped working, and to try to overcome the "non spinning" of the drive the client used another PSU which promptly blew the TVS. Initially this was just a platter swap with a PCB repair, but when the drive failed to initialise i swapped the heads as well.
Can anyone please point me in the right direction on this one, it's been hanging around a few weeks now and i would like to close it off, one way or the other... :|
Steve.
Igor
Re: Barracude 7200.10 ST3160815AS
Postby Igor » 22.08.11, 15:22
Paste please here terminal log that appears when you turn power on.
EADR
Postby EADR » 24.08.11, 08:33
Hi Igor,
Sorry for the late reply. I have attached 3 images of the Terminal. This is usually what you get when you power on
, but if you power of and on again a few times this is what sometimes comes up in the terminal window
and this continues to scroll and finishes here
Please let me know what you think may be the problem here...
Thanks..
Steve..
Igor
Postby Igor » 25.08.11, 17:02
Press CTRL+D several times while you will see ecr 111
Then press CTRL+C
Paste here log.
EADR
Postby EADR » 26.08.11, 09:18
Hi Igor,
Terminal output as requested...
thanks for your time on this...
Steve..
EADR
Postby EADR » 30.08.11, 10:56
Does anyone know how to get around this issue?....
Igor
Postby Igor » 30.08.11, 11:03
Sorry for delay. Reach me please via some instant messenger.
Postby AJ2008 » 07.09.11, 13:22
Is is possible to reach 'T>' in terminal ?
Can you read app code in Safe mode with no error?
