dear guru
accept my regards
i have a hdd in the following specification :
maxtor 120 gb , 6L120P0 , BAJ41G20
after i connect it to pc3000 , in universal utility window it shows
HDD does not support set max LBA
and in top left corner in front of capacity it shows : 128 GB
now i need to recover its data , but it is impossible
how can I do that ?
lots of apperciation in advance for you help
best wishes
mojimorady
i have a problem with maxtor 6L120P0
- mojimorady
Re: i have a problem with maxtor 6L120P0
Hello Mojimorady
BAJ41G20 Belongs to SABRE Maxtor family. You have to set jumpers to safe mode and load this drive with a loader. Please check SABRE Family within PC-3000 Maxtor utility manual.
Then you should run SA Structure test and check if there are any critical modules damaged. Tell me what are these modules.
Very likely this drive needs to have some damaged "B" modules rewritten.
If all modules are okay, you should try Autorecovery mode.
Please, download "autorecovery2.pcr" from your update box, import the resources to database, set your drive to safe mode and follow the steps, autorecovery mode will show you.
- mojimorady
Dear Roustam
thanks for your soonest response
i did what you told , load BAJ41G20 from database to HDD , and did SA STRUCTURE TEST , these modules were bad :
UBA Module ID copy importance read header CS
19683 1B 1 C yes error ok
19760 5E 1 Dr yes error ok
1075 7B 0 Dr yes ok error
20075 7B 1 Dr yes ok error
6824 A7 C yes error ok
i did not do autorecovery yet . waiting for your kindful answer , i should mention that i do not have
resources for this hdd . please if it is possible for you , send me its resources , my email address is :
mojimorady@msn.com
best regards
mojimorady
mojimorady@msn.com
best regards
mojimorady
- mojimorady
Dear Roustam
thank you so much for your help , i correct the modules manually , after that i used autorecovery , and now all
the data are accessible
it was your favour that i could recover the data
best wishes for you
mojimorady
best wishes for you
mojimorady
