Help with Samsung HM250HI
Moderator: Garry_TS
aribot
Postby aribot » 22.03.11, 14:23
Hello to everybody,
this is my first post, and my first case with PC3000, and hope someone can help me.
We have a Samsung HM250HI from the family M7S2 2.5" (SATA).
The HD doesn't make any suspicious noise.
It's detected by PC3000 and I could run some test. In fact I've runned physical reading test and the results are:
No problem reading with header 1, but with all errors when I choose the header 0.
Could be this mean a bad header which needs to be replaced?
Edited.
It's strange when reading SA , I can see in Terminal there is HEAD 0 reads, and there is no error.
Thanks in advance.
Alex.
Re: Help with Samsung HM250HI
Postby ACE_Admin » 29.03.11, 09:37
Hello Alex
Please attach SA Structure test report and terminal output to new message, its necessary to check it to answer you.
