HI GURU
I HAVE A HDD IN THE FOLLOWING SPECIFICATIONS :
80 GB IDE , YAR41BW0 , N,M,G,A ,
IT STARTS CLICKING , I CHANGED THE HEAD WITH SIMILAR ONE , NOW IT IS DETECTED ,
I TRIED TO SEARCH FOR NTFS STRUCTURE , BUT WHEN IT REACHES TO LBA NUMBER 45,000,000 , IT STARTS CLICKING
AND TURNED OFF , AFTER I TURNED IT UP , IT STARTS CLICKING AGAIN .
NOW WHAT SHOULD I DO ?
SHOULD I CHANGE THE HEAD AGAIN ?
AFTER THAT WHAT SHOULD I DO ?
THANKS ALOT FOR YOUR SOONEST REPLY
REGARDS
MOJI MORADY
6Y080L0 HEAD CHANGED
Re: 6Y080L0 HEAD CHANGED
You can set jumper to safe mode and start Maxtor Auto Recovery
if the drive start and can access to the user data start the DE and build head map and try to image the drive head by head
- mojimorady
dear hassan
tnx for your reply
but would you please teaching me how to create head map or
introduce any refrence about it to me ?
regards
moji morady
tnx for your reply
regards
moji morady
To build head map after Autorecovery success keep the maxtor utility open and start DE
in New Task create window select "Make data copy"
after De start go to service menu > buliding heads map
after building the map goto task options > heads map and select the head you want to imageing
- mojimorady
dear hassan
i learn lots of things from u , thank you so much !!!!!
i did all you said to me but on another hdd , now the question is how do you know
that the Data which i need is under which head , so i can select the appropriate head ?
regards
moji morady
regards
moji morady
You can not know where the needed data stored
So you should image all heads
But this method help if there is defect head or there are bad sectors in a zone in a platters
This hard drive belongs to Calypso family and this family can have autorecovery method launched.
Please check this topic to find out how to proceed with "Autorecovery" viewtopic.php?f=31&t=7017
- mojimorady
dear Roustam
Accept my regards
thank you for your reply , i did autorecovery . in the last step when it wants to start SA Defects , it shows the following line :
SA Defects checking Copy0............... : Module 37 reading error.; UBA 4 (1) reading error.; Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 89717/3/4SA Defects checking..................... : Ok
SA Defects.............................. : 0
P-List size............................. : 12 cekt
DISK reading............................ : DISK (Copy0) reading error: Module 1F reading error.; UBA 8 (1) reading error.; Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 89717/3/9DISK reading............................ : DISK (Copy1) reading error: Module 1F reading error.; UBA 15936 (1) reading error.; Techno cmd error. Cmd : 53. Code : 0111 C/H/S : 89758/3/192
DISK module initialization.............. : Module DISK reading errorRecovery process has been interrupted
Accept my regards
