ST3500418AS-FIRMWARE CC38-MODULE PROBLEM
RescueDRL@gmail.com
Postby RescueDRL@gmail.com » 07.01.11, 02:14
Hi, this Seagate 500GB drive had a blown motor chip and the ROM was transplanted to
a donor controller card. The drive now spins up, IDs itself correctly (after a LONG time),
but no data is read. There appears to be a module problem according to this PC3K-UDMA
screenshot. Modules 08, 0A, 0E, 15, and 3A are not read. Which of these need to be replaced?
Thanks,
Chris
PC3000 Resources Backup
dmarques
Re: ST3500418AS-FIRMWARE CC38-MODULE PROBLEM
Postby dmarques » 07.01.11, 16:48
What you can do is get a good working drive and check visually what is the purpose of those modules.
Alexandre Silveira
Postby Alexandre Silveira » 20.07.11, 05:33
I have these modules you still need?
