Help with PC3KU log of WD20EADS
RescueDRL@gmail.com
Postby RescueDRL@gmail.com » 01.01.11, 02:11
Hi and Happy New Year! This 2TB WD20EADS "almost" images on DDI, but then soon has problems reading. I attached a screen shot of the PC3000-UDMA log that appears upon initialization of the WD-Marvell utility.
Please advise what this is telling me and how to use PC3KU to fix it (if possible)
Thanks!
Chris
dmarques
Re: Help with PC3KU log of WD20EADS
Postby dmarques » 03.01.11, 09:53
Can you post SA structure test to check what modules are damaged?
RescueDRL@gmail.com
Postby RescueDRL@gmail.com » 03.01.11, 18:52
Here it is:
Id : Importance: ABA :Size:Read : Hdr : CS : CS Value: Vers. : Desription
Zone allocation table
HDDs RAM reading error - Device Error Detected: "SCT INVALID FUNCTION CODE"
MODULES DIRECTORY (01)
Not found in modules directory
CONFIGURATION MODULE (02)
Log DCM (C5)
dmarques
Postby dmarques » 04.01.11, 11:21
Can you read modules by ID?
Can you read service tracks?
RescueDRL@gmail.com
Postby RescueDRL@gmail.com » 05.01.11, 19:59
I get an error with the ID. And when I try tracks, it takes many hours even for the first one.
Obviously something wrong
dmarques
Postby dmarques » 06.01.11, 15:43
Have you tried to read them after hotswap?
