WD800JD-00LSA0 Knocking
Issam
Postby Issam » 02.08.10, 21:07
Recently I received 5 drives wd WD800JD-00LSA0, Sabre58 Unicron, same symptoms:
Knocking, then spinning down.
Hot Swap Does Not Work.
Heads changing , does not work.
Even I bring a good donor, I withdrew its heads and returned them to the donor, the donor starts clicking.
What I want to know: Is there any way to align heads in WD800 Sabre58 Unicron. I think there is heads alignment problem. Please try to help me.
N.C.
Re: WD800JD-00LSA0 Knocking
Postby N.C. » 03.09.10, 11:49
Issam wrote:Recently I received 5 drives wd WD800JD-00LSA0, Sabre58 Unicron, same symptoms:
If you are not ruined the chance allready (with surface problems) i can help, but not remotely.
Janos
crobison
Postby crobison » 30.09.12, 03:05
janos,
I have the same exact problem with a WD800JD-75LSA0. I understand that these wd have a screw on the top that holds the head arm in place and once you remove the top, the heads become unaligned. My question is how to you align this issues? I have a pc3000, ddi, etc....
This is what I get...
Service area:
SA dir reading (ID)..................... : Unknown error. Error code: 4343
Thanks..
Balvan
Postby Balvan » 06.10.12, 20:49
Remove the patient PCB and power it on. Check the discrete components beneath the motor IC. If they are hot, the PCB is killing heads.
A good strategy is to use a replacement PCB when doing head swaps on this family, to make sure the PCB is not causing problems.
